Pendant with axis select buttons
23 Nov 2021 10:43 - 23 Nov 2021 10:46 #227392
by Wischi
Pendant with axis select buttons was created by Wischi
Hello,
i am trying to convert an original Deckel FPA pendant to LinuxCNC. The pendant has six buttons, normally open ,momentary, with a 24V LED. One for each of the Axis (X,Y,Z,C) and two for the scale (100,10). The scale buttons I set to 100 for 0.01mm and 10 for 0.1mm and C will be A on my machine at some point. I have the buttons working in HAL with their led and axis.N.jog-enable as well as the scale. But it is possible to select multiple axis and scales at the same time. My idea was to first select an axis and then the scale. Then when switching, for example, from X to Y, the X Led turns off and axis.x.jog-enable goes to 0 and Y led turns on and axis.y.jog-enable goes to 1. The scale will be unchanged. And when all axis switches are off the encoder would act as a feed override. But that is something for later on.
Here is my current HAL. I appreciate every tip on how to code in HAL since this is my first time doing something like this. For example the use of mux4, it works but I think it is not that good/correct to do.
loadrt toggle2nist count=6
loadrt toggle count=6
loadrt mux4 count=1
addf mux4.0 servo-thread
setp mux4.0.in0 0
setp mux4.0.in1 0.01
setp mux4.0.in2 0.1
setp mux4.0.in3 0
net mpg-scale <= mux4.0.out
net mpg-scale => axis.x.jog-scale
net mpg-scale => axis.y.jog-scale
net mpg-scale => axis.z.jog-scale
net mpg-scale => axis.a.jog-scale
addf toggle2nist.0 servo-thread
addf toggle2nist.1 servo-thread
addf toggle2nist.2 servo-thread
addf toggle2nist.3 servo-thread
addf toggle2nist.4 servo-thread
addf toggle2nist.5 servo-thread
addf toggle.0 servo-thread
addf toggle.1 servo-thread
addf toggle.2 servo-thread
addf toggle.3 servo-thread
addf toggle.4 servo-thread
addf toggle.5 servo-thread
#Axis select buttons
net mpgx_btn toggle.0.in <= hm2_7i92.0.7i77.0.0.input-00
net mpgx_btn_in toggle2nist.0.in axis.x.jog-enable hm2_7i92.0.7i77.0.0.output-00 <= toggle.0.out
net mpgy_btn toggle.1.in <= hm2_7i92.0.7i77.0.0.input-01
net mpgy_btn_in toggle2nist.1.in axis.y.jog-enable hm2_7i92.0.7i77.0.0.output-01 <= toggle.1.out
net mpgz_btn toggle.2.in <= hm2_7i92.0.7i77.0.0.input-02
net mpgz_btn_in toggle2nist.2.in axis.z.jog-enable hm2_7i92.0.7i77.0.0.output-02 <= toggle.2.out
net mpga_btn toggle.3.in <= hm2_7i92.0.7i77.0.0.input-03
net mpga_btn_in toggle2nist.3.in axis.a.jog-enable hm2_7i92.0.7i77.0.0.output-03 <= toggle.3.out
#Scale buttons
net mpg10_btn toggle.4.in <= hm2_7i92.0.7i77.0.0.input-05
net mpg10_btn_in toggle2nist.4.in mux4.0.sel0 hm2_7i92.0.7i77.0.0.output-04 <= toggle.4.out
net mpg100_btn toggle.5.in <= hm2_7i92.0.7i77.0.0.input-04
net mpg100_btn_in toggle2nist.5.in mux4.0.sel1 hm2_7i92.0.7i77.0.0.output-05 <= toggle.5.outÂ
Last edit: 23 Nov 2021 10:46 by Wischi.
23 Nov 2021 17:00 #227421
by Henk
Replied by Henk on topic Pendant with axis select buttons
I would have used classic ladder for this. But that is just my preference....
Time to create page: 0.056 seconds
