Working config for xhc-whb04b-4 pendant
22 Feb 2024 20:37 #294015
by Halbear
Replied by Halbear on topic Working config for xhc-whb04b-4 pendant
Hi Erik,
Sorry to bump an old thread but I can't seem to make this work. After commenting out pin erroring lines I come back to the most common error which is like 13 or 14 containing "loadusr."
Any idea what this could indicate? The permissions file is correct, and I've been trying your steps in addition to adding the "source xhc-whb04b-6: line in custom.hal.
Running the latest 2.9 on Deb 12 with a 7i96s btw
- smc.collins
- Thank you received: 109
22 Feb 2024 21:18 #294018
by smc.collins
Replied by smc.collins on topic Working config for xhc-whb04b-4 pendant
a few weeks ago someone posted a much corrected version of this configuration, Erik left out information
The following user(s) said Thank You: Halbear
22 Feb 2024 21:49 #294022
by Halbear
Do you happen to remember what it was under? I've read through a bunch of the pendant stuff but a lot of it I can't do (eg watching input) because I can't even start up Axis if the xhc-whb04b-6-related mods are in the files. It just seems to get stuck at the loadusr hal_input line
Thanks,
Hal
Thanks,
Hal
- smc.collins
23 Feb 2024 03:25 #294045
by smc.collins
23 Feb 2024 05:48 - 23 Feb 2024 05:49 #294049
by Halbear
Awesome thanks for finding that! I was literally just doing the same thing, deleting halui entries and just checked to see if those entries still worked and they did!
The biggest holdup though - the line 13/14 hal_input error seemed to be caused by manually entering "source xhc-whb04b-6" into the custom.hal file. Once I got rid of that, Axis was starting up. Still no handwheel control but maybe the post you linked will clear that up
Thanks again! I'd buy you a beer if you were nearby
Last edit: 23 Feb 2024 05:49 by Halbear.
Time to create page: 0.107 seconds
