ArduinoIO HAL component
01 May 2023 20:50 #270429
by dinodf
Replied by dinodf on topic ArduinoIO HAL component
It's fixed the BUG?
26 Sep 2023 23:46 - 27 Sep 2023 01:22 #281683
by dokwine
Replied by dokwine on topic ArduinoIO HAL component
Hi Dino,
I came across this and was considering giving it a try. I see that that the .py code stipulates <2.7, and I’m running 2.9 pre now (which I think is >Python 3). Would you expect it to work with 3, or do you plan to update?
thanks, Ron
thanks, Ron
Last edit: 27 Sep 2023 01:22 by dokwine.
27 Sep 2023 21:13 #281741
by dinodf
there is no problems to use the code as is with python 3.x.y the __future__ statements is necessary only for use the print function in the newer format
I'm happy to know your feedback. I have draw a little PCB to control the spindle inverter with an Arduino NANO Every, if it's useful I can publish the schematic and the board.
Dino
Dino
27 Sep 2023 23:45 #281750
by dokwine
Thanks for the reply. I think I’m about ready to try this out… need the remote IO’s for a new control panel. There will probably be some questions as some of this is new territory for me.
The following user(s) said Thank You: dinodf
- AlexMagToast
- Thank you received: 66
28 Sep 2023 19:19 #281812
by AlexMagToast
Replied by AlexMagToast on topic ArduinoIO HAL component
i just stumbled upon your project. I've been working on a similar project too.
Maybe we can cooperate.
github.com/AlexmagToast/LinuxCNC_ArduinoConnector
The following user(s) said Thank You: zmrdko
10 Oct 2023 22:42 #282709
by dokwine
I just stumbled across your YT channel by accident nice stuff!
Just bumbling my way through this starting from an ESP32-S3. Haven't been able to put much time into it yet
The following user(s) said Thank You: AlexMagToast
21 Feb 2024 14:42 #293909
by zmrdko
Replied by zmrdko on topic ArduinoIO HAL component
Nicely done. Up and running in 5 minutes!! Good job and thank you!i just stumbled upon your project. I've been working on a similar project too.
Time to create page: 0.254 seconds
