Using HAL from Python
25 Jan 2023 09:19 #262865
by juniorfi
Using HAL from Python was created by juniorfi
Hi!
I'm tying to be able to get and change pins values from Python.
I have been trying it for a while Cython but haven't got it working. The best near approach I have made, was today re-using HAL Python library that LinuxCNC includes by default on the images provided.
Files used and placed under /usr/lib/....:
- _hal.arm-linux-gnueabihf.so
- hal.py
- hal.pyc
- hal_glib.py
- hal_glib.pyc
- liblinuxcnchal.so.0 (Would like to know how compile it)
My setup is with a RPi4 + EtherCAT modules. -All working nicely- using HAL-CORE right now:
github.com/grotius-cnc/hal-core
This is my runtest file:
The issue I'm facing right now is when using this code, is the halrun version code mismatch:
The code I used:
My idea is to be able to use it in real-time (I know Python isn't the best for it) but approximately will be great. Because actually I'm calling halcmd every time I want to do a movement, and that's not the best way of doing it.
Best regards!
- hal.py
- hal.pyc
- hal_glib.py
- hal_glib.pyc
#!/usr/bin/bash
# Startup hal-core
cd /opt/hal-core/scripts/ && . ./rip-environment
cd /opt/hal-core/bin
halcmd stop
halcmd loadrt threads name1=base-thread fp1=0 period1=1000000
#name2=servo-thread period2=1
# Unix command to load the ethercat .xml config
/opt/hal-core/rtlib/./lcec_conf /opt/hal-core/rtlib/ethercat-conf.xml &
halcmd loadrt lcec
halcmd net ec-slaves-responding <= lcec.slaves-responding
halcmd net ec-link-up <= lcec.link-up
halcmd net ec-all-op <= lcec.all-op
halcmd addf lcec.read-all base-thread
halcmd addf lcec.write-all base-thread
halcmd start
HAL: ERROR: version code mismatch
HAL: ERROR: could not init shared memory
File "test", line 3, in <module>
h = hal.component("lcec")
hal.error: Invalid argument
The code I used:
#!/usr/bin/env python
import hal, time
h.newpin("in", hal.HAL_FLOAT, hal.HAL_IN)
h.newpin("out", hal.HAL_FLOAT, hal.HAL_OUT)
h.ready()
try:
while 1:
time.sleep(1)
h['out'] = h['in']
except KeyboardInterrupt:
raise SystemExit
Best regards!
25 Jan 2023 09:25 #262866
by juniorfi
Replied by juniorfi on topic Using HAL from Python
The actual Cython ( file_name.pyx ) code is the following in case someone want to have a look:
#!python
#cython: language_level=3
cdef extern from "rtapi_app.h":
cdef int hal_init(char* name)
cdef void hal_ready(int comp_id)
cdef void *hal_malloc(int size)
cdef int hal_pin_float_new(char* name, void* ptr, int comp_id)
cdef void hal_pin_float_set(int pin, double value)
cdef double my_pin_value
def main():
cdef int comp_id
comp_id = hal_init("lcec.0.3.din-0-not")
my_pin_value = hal_malloc(sizeof(double))
hal_pin_float_new("lcec.0.3.din-0-not", my_pin_value, comp_id)
hal_ready(comp_id)
return <object>my_pin_value
if __name__ == "__main__":
main()
25 Jan 2023 09:49 #262868
by juniorfi
I just saw that there was already kind of Cython implementation from a LinuxCNC fork:
github.com/machinekit/machinekit/tree/master/src/hal/cython
28 Jan 2023 17:15 #263095
Replied by andypugh on topic Using HAL from Python
I am not sure quite why you are using cython?
The best way to do this would be to make a Python HAL component, create an output pin in that component, and net that (In HAL) to the pin you want to change the value of.
linuxcnc.org/docs/stable/html/hal/halmodule.html
However, it might be better (and a _lot_ more realtime, to do it in a C realtime component:
This link will take you to some examples that show just how little programming can be needed for a simple HAL component.
linuxcnc.org/docs/stable/html/hal/comp.html#_sincos
Though you would need to read the rest to do it...
The following user(s) said Thank You: juniorfi
28 Jan 2023 21:11 #263120
github.com/LinuxCNC/linuxcnc/commits/python3_cython
Are you trying to speed python up?
Replied by cmorley on topic Using HAL from Python
also here, though it didn;t go anywhere:I just saw that there was already kind of Cython implementation from a LinuxCNC fork:
30 Jan 2023 14:48 #263239
by juniorfi
My goal is to be able to communicate with the pins with ROS.
www.ros.org/
To be able to do that, I need to use Python or C++, because those are the language levels that ROS uses natively.
I was thinking in Cython, because I could use the RTAPI_APP libraries to communicate with the pins already created after -halcmd start- + wrapped in Python.
Thanks for the link you sent me.
I was today thinking to modify halcmd and try to add there the C++ ROS code there. But probably that will not be best way to access to the pins already created and modify it.
Thanks again for the information provided.
Regards
www.ros.org/
Regards
30 Jan 2023 14:50 #263240
by juniorfi
Thanks for the link. I haven't see that branch before...
My goal is to be able to communicate with the pins from ROS ( www.ros.org/ ).
Python and C++ is already supported, but not C. I will need to read how to wrap C++ in C code to do that I guess.
Regards
Regards
30 Jan 2023 16:00 #263244
by Grotius
Replied by Grotius on topic Using HAL from Python
Modifying halcmd is a good practice.
I would problably write a tiny python-c++ binding class to achieve goal.
that uses a method like : www.geeksforgeeks.org/how-to-call-c-c-from-python/
Another example that uses this method:
github.com/grotius-cnc/XCreator/blob/mai...ient/patch/skynet.py
Background info : github.com/tdegeus/pybind11_examples/issues/11
30 Jan 2023 16:06 #263246
by Grotius
You can just recompile lcnc.
Or here is a cmake file for just only the liblinuxcnchal.so
github.com/grotius-cnc/linuxcnc/blob/mai...nchal/CMakeLists.txt
If you should open : github.com/grotius-cnc/linuxcnc/blob/main/cmake/CMakeLists.txt
in qt. You will see the bird view of lcnc, And you can compile each item you want to.
07 Mar 2023 19:16 #266056
by juniorfi
Thanks for the information you provided.
Now I will change my focus on C/C++ instead Python.
I think I will get more flexibility and compatibility overall.
Regards.
Regards.
Time to create page: 0.107 seconds
