using Classic ladder to setup controls for invertek VFD
05 Feb 2023 06:37 #263739
by gerrg
using Classic ladder to setup controls for invertek VFD was created by gerrg
Hello! I just got a new VFD (old one died), and i'm trying to get linuxCNC to control it. I've got a the classic ladder part of it setup correctly as far s the CPL file goes (i think at least), but i'm now unsure how to actually link those registers from classic ladder to the signals on linuxCNC. I'm starting off using files from the YL VFD config stuff
here
, but then i'm not sure how to actually access the values from classic ladder. Here's a picture of my classic ladder setup screen:
so the first line should be reading some values like motor speed, motor current, etc. Line 2 should be "Run Enable" (setting bit 0 high enables the spindle). Line 3 should be setting the spindle speed (in Hz I think, where a value of 1000 = 100.0 Hz)
I installed modpoll on the linux computer so i could send modbus commands through the rs485 connection i'm using (usb to rs485), and I'm able to turn the spindle on by setting register 1 to a value 1, and turn it the spindle off by setting a value of 0 as expected, and I can change the speed of the spindle by setting register 2 to a value of 1000 or 1100 (100Hz/6000RPM and 110Hz/6600RPM respectively)
so i guess my question is how can i set these register values from classic ladder to nets. the example link up at the top of this post for the YL VFD has lines like
... but i'm not really sure what those are meaning. I maybe classicladder.0.in-00 is the first value read from the first classic ladder register (assming that first register is reading multiple values).... but then classicladder.0.floatin-00 i would think would reference a floating point value of that same register value, so i'm getting confused
Any help sorting this out would be appreciated! Thanks!
net spindle-on classicladder.0.in-00 spindle.0.on
net spindle-brake classicladder.0.in-01 spindle.0.brake
net spindle-forward classicladder.0.in-02 spindle.0.forward
net spindle-reverse classicladder.0.in-03 spindle.0.reverse
net spindle-cmd-rpm <= spindle.0.speed-out
net spindle-cmd-rpm-abs <= spindle.0.speed-out-abs
net spindle-cmd-rps <= spindle.0.speed-out-rps
net spindle-cmd-rps-abs <= spindle.0.speed-out-rps-abs classicladder.0.floatin-00
06 Feb 2023 12:46 #263816
Replied by andypugh on topic using Classic ladder to setup controls for invertek VFD
I have never used CL, so this is a guess, but I would imagine that you need ladder rungs that connect the HAL pin values as inputs to the Modbus outputs.
- M4MazakUser
- Thank you received: 3
12 Apr 2023 10:57 #268883
by M4MazakUser
Replied by M4MazakUser on topic using Classic ladder to setup controls for invertek VFD
I wish I could remember what I learnt 12 years ago... I'm setting up modbus to set a speed on a vsd and have just spent all day !
12 Apr 2023 11:17 #268885
Do you want to spend even more time in experiimentation using a new and undocumented HAL component?
Are you using a Mesa card with a spare RS422 port?
Are you not really all that interested in getting the VFD to work?
If the answer to all these questions is "Yes" then:
github.com/andypugh/mesa_modbus
12 Apr 2023 14:46 #268900
by scotth
Replied by scotth on topic using Classic ladder to setup controls for invertek VFD
This might help.
- M4MazakUser
26 Apr 2023 11:34 #269969
by M4MazakUser
I worked out mine, once I worked out that the 4 wire usb-rs485 had to be a 2 wire unit as even with the positives and negatives bridged it was echoing.
then communication was easy except for the fact that the binary values in the manual were upside down. This made it hard to work out which was the high and low word...the ladder bit is easy. Its just setting values from halui to the drive. - as its all s32 not float the conversion for speed (as its 2:1) has to be done using integers, therefore you divide and subtract by the amount of division.
Time to create page: 0.168 seconds
