Spindle Control reverse and forward problems
- Thank you received: 5967
08 Feb 2023 12:50 #264036
Replied by tommylight on topic Spindle Control reverse and forward problems
Where is the M4 part?
08 Feb 2023 18:58 #264069
by DSS
Replied by DSS on topic Spindle Control reverse and forward problems
It has been a while since I have had a Precision Matthews mill. Looking through my hard drive I can not find my old HAL files however I did still have this active low fwd/rev pdf from Peter saved (same as mentioned in post
#263761
). I don't recall off hand if the fwd/rev com is low or high so check before wiring and update accordingly.
- bird-dogman
10 Feb 2023 22:26 #264255
by bird-dogman
Replied by bird-dogman on topic Spindle Control reverse and forward problems
Thank you
jim
jim
- bird-dogman
16 Feb 2023 19:41 #264639
by bird-dogman
The first relay arrived DOA and returned to Amazon. Ordered three pack of DIN rail minis for $26.
Wired per diagram works great both forward and reverse.
Thank you all
jim
Thank you all
jim
02 Mar 2023 04:16 #265693
by a.smith
Replied by a.smith on topic Spindle Control reverse and forward problems
I take it you got your 728VT working with the 0-10V spindle control board they offer? Did you hook it to the analog spindle output on the 7i76e? It seemed to me that using their addon board with the 7i76e would require a separate 10V source, but I haven't made it that far in my conversion yet.
I was going to completely omit the board and use the 7i76e analog control directly with the main spindle driver board pot wiring which is about 5V.
- bird-dogman
02 Mar 2023 20:41 #265738
by bird-dogman
Yes its working as it should.
Follow the MESA directions for connecting to the spindle which will supply the 0-10 volts for speed control.
Use the above document to finish the remaining connections along with 1 relay.
Works great.
Jim
Works great.
Jim
- bird-dogman
02 Mar 2023 20:49 #265739
by bird-dogman
I used a cheap buck converter to go from 24v to 10v. I might replace it at some point.
Jim
Jim
Time to create page: 0.107 seconds
