HAL to user process event passing
28 Mar 2023 00:46 #267654
by zdenek
HAL to user process event passing was created by zdenek
I need to signal upstream from boolean HAL pins or signals to a user space process, using a proper kernel-based IPC so the [slow] user space process can be suspended until signaled from a [fast] HAL thread. I could not find anything like that when consulting the existing component list, so I am about to create this component. But before I do I wanted to see if I was perhaps missing anything or if anyone had any other suggestions.
I am envisioning to simply take a boolean input and send it over via one of the standard IPC mechanisms, likely a message queue or a pipe.
Thanks!
Thanks!
31 Mar 2023 08:21 #267954
by bkt
Replied by bkt on topic HAL to user process event passing
31 Mar 2023 14:51 #267966
by zdenek
Replied by zdenek on topic HAL to user process event passing
Thanks. I just wanted to check if I was missing an existing mechanism/component.
I have already written the real-time component (and it's user process counterpart) I needed -- it took just a few lines of code.
Cheers
Cheers
01 Apr 2023 06:20 #268008
by bkt
good.
Have a nice Lcnc adventure.
Time to create page: 0.103 seconds
