Mesa pktUART RT Modbus Driver
20 Apr 2023 17:39 #269495
by 0x2102
Mesa pktUART RT Modbus Driver was created by 0x2102
Related to Andy's announcement here:
forum.linuxcnc.org/29-forum-announcement...or-mesa-cards#269395
I wanted to create a new discussion thread to talk about Mesa pktUART RT Modbus Driver.
First off, thanks a lot Andy for your work on the driver.
I was very curious and had to try it right away, but I can't get it to work.
Here is what I did:
1.) Flashed my 7i96 with the pktUART firmware
sudo mesaflash --device 7i96 --addr 10.10.10.10 --write 7i96_pktd.bit
2.) Downloaded and installed Andy's branch
3.) Created a simple xy-md02.mod - for a Modbus temperature / humidity sensor (working with modpoll)
4.) Modcompiled and installed OK. Added loadrt xy-md02 ports=hm2_7i96.0.pktuart.0 and addf xy-md02 servo-thread
5.) LinuxCNC starts, but I don't get any values. Modbus settings should match defaults: 9600 / no parity
but I also played with almost all combinations.
6.) I have checked the wiring and tried flipping the cables, too. No difference.
RX- and TX- to B
RX+ and TX+ to A
Endless terminal output is this:
WAIT_FOR_DATA_FRAME - rxmode = 3FE00F8E
Test script output:
cnc@lcnc-dev:~/linuxcnc-andypugh-mesa_modbus/src/hal/drivers/mesa-hostmot2/modbus$ ./test-mod.sh
00200A20
3FE1148E
00008015
00000000
00000000
Not sure what else I can try. Any other debugs I can enable?
Here is what I did:
RX- and TX- to B
RX+ and TX+ to A
Test script output:
00200A20
3FE1148E
00008015
00000000
00000000
20 Apr 2023 18:36 - 20 Apr 2023 18:39 #269500
Replied by PCW on topic Mesa pktUART RT Modbus Driver
The '1' bit set on the RX mode register indicates a overrun error
(no stop bit when expected)
This may be because of incorrect baud rates or undriven differential
bias levels on the RX lines generating a continuous line break.
Last edit: 20 Apr 2023 18:39 by PCW.
- MennilTossFlykune
- Thank you received: 14
21 Apr 2023 13:15 #269552
by MennilTossFlykune
Replied by MennilTossFlykune on topic Mesa pktUART RT Modbus Driver
Can someone help me compile it?
This is as far as I get: undefined symbol: hm2_pktuart_queue_get_frame_sizes
I'm not sure I filled in the header correctly either so I've attached my vfdmod configuration instead
Time to create page: 0.116 seconds
