Need help trying to build and install custom components
02 May 2023 11:43 #270475 by rodw
Just follow the dev install
linuxcnc.org/docs/2.9/html/code/building-linuxcnc.html
in the terminal window you are using, you will need to type
. ~/linuxcnc-dev/scripts/rip-environment
Not the leading period followed by  a space
Closing that window should restore normal deb installed function
I did do a video
The following user(s) said Thank You: JPL
Time to create page: 0.061 seconds
