Hal configuration 7i96s + 7i85 + whb04-6
- routerman22
- Thank you received: 7
10 Jul 2023 15:20 - 10 Jul 2023 15:27 #275139
by routerman22
Hal configuration 7i96s + 7i85 + whb04-6 was created by routerman22
Hi All,
It has been a while since my last post, but there has been some progress in the build. This is a follow-up of :
forum.linuxcnc.org/39-pncconf/47881-index-homing-mesa-7i96s
I'm running lcnc 2.9.0
I have flased my 7i96s with (in mesact fw list):
As mesact does not fully support my configuration i did the base config in pncconf:
(see attachement). This works (note without the XHC-WHB04B-6 stuff)
I tested the XHC-WHB04B-6 pendant via the command line and that works well.
When i tried to integrated it into my config i get all kind of signal does not exist messages, starting from line 49 (see attachement).
The items remaining to get my build working are as follows:
- Add 4 encoder inputs from the 7i85 (differential + index) the the X,Y,Y1,Z axis (10000 ppr) to the config
- Fix the WHB04B-6 hal signal issues.
The connection of the 7i85 is as follows:
ENC0 = X
ENC1 = Y
ENC2 = Y1
ENC3 = Z
Note: i dont use lcnc for doing anything to the control loop, that is handled in the delta drive.
I need the index for doing index homing on the lcnc side.
I'm quite new to hal file editing, and i'm having a hard time figuring this out. any help would be appriciated.
- 7i96s_7i85d.bin
- 5 Axes of Step and Direction
- 1 Encoder Input
- 1 Smart Serial Port
- 11 Inputs 6 Outputs
- P1 Daughter Card 7i85
- 5 RS-422 Serial Channels
- 4 Encoder Inputs
ENC0 = X
ENC1 = Y
ENC2 = Y1
ENC3 = Z
Last edit: 10 Jul 2023 15:27 by routerman22.
- routerman22
10 Jul 2023 18:20 - 10 Jul 2023 18:36 #275148
by routerman22
Replied by routerman22 on topic Hal configuration 7i96s + 7i85 + whb04-6
There is progress!
I basically got the WHB pendant to work. had to comment out a lot of HALGUI stuff in my machine hal file.
Only weird thing is that the component seems to crash at some point. causing linuxcnc not to be able to detect it anymore,
And the information on the screen (pendant) to be out of date.
youtube.com/shorts/NsYFCCLa8Lc
Last edit: 10 Jul 2023 18:36 by routerman22.
- routerman22
10 Jul 2023 19:09 #275150
by routerman22
More progess: I added AND2 component as I'm using Delta ASDA-M to put my Y axis in Gantry mode.
it is in individual mode untill it is homed, after an IO needs to be put HIGH to allow it to go in gantry mode.
I used the following component and signals:
#AND logic (to enable DELTA ASDA-M Y axis gantry function when Y,Y1 is homed
loadrt and2 count=1
addf and2.0 servo-thread
net my-sigin1 and2.0.in0 <= joint.1.homed
net my-sigin2 and2.0.in1 <= joint.2.homed
net both-on [HMOT](CARD0).ssr.00.out-03 <= and2.0.out
#end of AND logic code
Updated files added
loadrt and2 count=1
Updated files added
- routerman22
10 Jul 2023 20:48 #275158
by routerman22
- routerman22
10 Jul 2023 21:32 - 10 Jul 2023 21:33 #275164
by routerman22
Last edit: 10 Jul 2023 21:33 by routerman22.
- routerman22
11 Jul 2023 07:28 #275194
by routerman22
Does anybody happen to have a working encoder + index hal which I could use as the basis of mine?
11 Jul 2023 13:31 - 11 Jul 2023 15:02 #275209
Replied by PCW on topic Hal configuration 7i96s + 7i85 + whb04-6
Typically the index pin signal is too short to reliably check with halshow or halmeter
(especially at high encoder resolutions). This is because the GUI only samples the hal pin every
50 ms or so and even LinuxCNC only samples the pin at about 1 ms intervals. This is why
the index is detected in hardware and the index handling in hal is done with index-enable,
not the index pin itself.
To check an index input, use halcmd to set the index-enable signal true and the see if
index-enable goes false at the index location, for example:
halcmd -kf
halcmd: sets x-index-enable 1
(rotate shaft and check for x-index-enable going false)
halcmd -kf
Last edit: 11 Jul 2023 15:02 by PCW.
The following user(s) said Thank You: routerman22
13 Jul 2023 00:51 #275308
by Hakan
Replied by Hakan on topic Hal configuration 7i96s + 7i85 + whb04-6
Regarding the occasional crash. The pendant component is compiled with the assert() function activated. Deactivate assert() and recompile the component. There will still be the occasional crash but the component will recover and continue to work after a second or two.
- routerman22
14 Jul 2023 21:58 #275451
by routerman22
Did not have any ussue with it anymore. I must have done something dumb.
- routerman22
14 Jul 2023 22:05 - 14 Jul 2023 22:11 #275452
by routerman22
I think i found a bug in lcnc.something very strange happens when i enable the index homing.Note: homing with index = no works perfect. With yes weird stuff happens:Step 1 machine is on, x axis is (lets say middle of travel 400mm)Step 2 home x-axisaxis goes to home switch -> backs off home switch -> looks for index -> index found -> instead of setting that point as machine origin (normal behavoir), it still thinks machine origin = position of axis when you turn the machine on. So in this case it thinks index is at -400mm , instead of machine origin (0mm). It will now move the 400 mm back (back to axis position when it was turned on) using hom final velocity speed.When i set index homing back to no it works as expected. Im very confused. I have tested the index independently via the procedure listed above.My version is: axis.ngc-AXIS 2.9.0~prel git20230208.f1270d6ed7oneither im missing something or there is a bug in my version. Im very confused ?
Last edit: 14 Jul 2023 22:11 by routerman22.
Time to create page: 0.184 seconds
