Looking for a hal component
13 Jul 2023 09:46 #275322
by beefy
Replied by beefy on topic Looking for a hal component
OK, so far, so good.
I think I've successfully used Halcompile to make my 64 output demulitplexer.
It installed it to this path:
/usr/lib/linuxcnc/modules
The file extension was .so
In tutorials I've seen them talk about .ko files for hal components, so what's the difference between a .so file and a .ko file ?
On a sidenote I did a search from the root directory for "and2.*" and only got and2.so in the above mentioned directory which was full of what appeared to be all the hal components, as .so type files.
I could not find any directory with and2.ko
13 Jul 2023 10:58 #275325
by rmu
Replied by rmu on topic Looking for a hal component
".so" means "shared object" file, ".ko" is the ending usually used for kernel modules. Depending on your realtime system, either .so is generated for userspace RT Preempt, or kernel modules for RTAI.The file extension was .so
13 Jul 2023 18:12 #275361
by beefy
Thanks very much Rmu.
Mine is the RT Preempt so that all makes sense now.
13 Jul 2023 23:16 #275381
Replied by rodw on topic Looking for a hal component
On the main online docs page of the version you are running, you will find a Heading called man pages. Under that is a button called expand man pages. Be sure you click on it and always leave it expanded.
That will display a copy of all of the man pages that you can access from the command line (eg man and2). This documentation is generated from the source code of each component. Happy reading!
15 Jul 2023 00:28 #275467
by beefy
Thanks Rod, got a tab permanently open with that now. Very handy.
I tested my 64 output demultiplexer with halcmd and it seemed to work great so I'm over the moon.
I feel like I'm well on the way to designing my super pendant.
Time to create page: 0.145 seconds
