- Configuring LinuxCNC
- HAL
- How to display the value of the int variable from the hal_parport.c file in the
- drzasiek90
- Thank you received: 9
05 Sep 2023 11:44 #279946
by drzasiek90
How to display the value of the int variable from the hal_parport.c file in the was created by drzasiek90
Hi, I'm compiling my own version of LinuxCNC and making some changes to thefile. I would like to be able to display the value of a variable in the Axis panel in a way similar to how spindle speed is displayed using a HAL pin. Can someone guide me on how to achieve this?
hal_parport.c
05 Sep 2023 12:45 #279960
by cornholio
Replied by cornholio on topic How to display the value of the int variable from the hal_parport.c file in the
You may want to elaborate a little more.
What variable ?
Where is coming from ?
What variable ?
05 Sep 2023 14:34 #279979
Replied by andypugh on topic How to display the value of the int variable from the hal_parport.c file in the
Maybe create a new HAL pin or parameter and set the value of it inside your new comp.
- drzasiek90
06 Sep 2023 05:23 #280054
by drzasiek90
Replied by drzasiek90 on topic How to display the value of the int variable from the hal_parport.c file in the
I create a global variable in the source file that takes certain values in certain situations. I compile linuxcnc and run. I would like to be able to view the value of this variable while the program is running.
06 Sep 2023 08:09 - 06 Sep 2023 08:09 #280067
Create your variable in the HAL structure and assign it to a parameter (you can copy the structure of the other pins / params)
Then you can use the existing HAL tools to monitor the value, including displaying it in GUIs.
Last edit: 06 Sep 2023 08:09 by andypugh.
- drzasiek90
06 Sep 2023 09:40 #280078
by drzasiek90
No, I've already done it.
I am able to view the parameter in tools.
However, I would like to display this value permanently, but using pycvp it is probably not possible - so far I have not succeeded.
Using pyvcp I am successfully displaying the hal pins but the hal parameters are not working.
06 Sep 2023 10:18 #280081
by cornholio
Oh ok, you want to modify Axis to display the value ?
06 Sep 2023 10:44 #280083
(Which means that it needs to be part of the hal_malloc data and needs to be a pointer to a pointer)
PyVCP can only display items that can be "net"-ed to the PyVCP pins in HAL. So you will need to create the variable as a pin, not as a parameter.Using pyvcp I am successfully displaying the hal pins but the hal parameters are not working.
- drzasiek90
06 Sep 2023 10:44 #280084
by drzasiek90
If necessary.
However, I'd prefer to do without modification by adding a panel via pyvcp.
I am looking for a simple method so that it is easy to replicate.
- HAL
Time to create page: 0.117 seconds
