HAL, GUI IO test panel, and ClassicLadder etst procedures
- tropostudio
- Thank you received: 4
06 Sep 2023 18:04 #280131
by tropostudio
I'm looking for input on a best approach to testing a large ClassicLadder program with a lot of physical IO into my Howa VMC retrofit.
Current status of the machine:
# Panel LEDs
net auto-running gladevcp.auto-running_tglbutton => hm2_[HOSTMOT2](BOARD).1.gpio.048.out
net feed-hold gladevcp.feed-hold_tglbutton => hm2_[HOSTMOT2](BOARD).1.gpio.049.out
net all-home-pos gladevcp.all-home-pos_tglbutton => hm2_[HOSTMOT2](BOARD).1.gpio.050.out
I assume I could do something like this in file called howa-ladder.hal :
net Q0 classicladder.0.out-00 => hm2_[HOSTMOT2](BOARD).1.gpio.048.out
net Q1 classicladder.0.out-01 => hm2_[HOSTMOT2](BOARD).1.gpio.049.out
net Q2 classicladder.0.out-02 => hm2_[HOSTMOT2](BOARD).1.gpio.050.out
Would it be possible to 'exclusive or' the ClassicLadder inputs and outputs with corresponding gladevcp inputs and outputs, or would that cause problems with ClassicLadder IO being placed in the pgui.hal file?
After testing I will ditch or hide the gladevcp panel to avoid hazards of duplicitous IO.
- I can test/control all physical IO through a GladeVCP panel in Axis. The IO runs through 2 MESA 6i24 PCIe boards and IO optoisolation boards of my own make. MESA pins are set as required in in file howa-io.hal; GladeVCP panel is in file howa-io.ui; IO signals and pins are set up and connected in howa-pgui.hal.
- 7 Mitsubishi servo drives (6 position servos and 1 spindle) can be controlled though Axis via one of dmitry's YMDS2P interface cards. HAL pins are set and connected in howa-nyx.hal. Connections to Axis interface pins for the servos are made in howa-io.hal.
- Old Meldas ladder for the machine has been transcribed into desktop version of ClassicLadder. It works pretty well in software -still debugging. It's a really big CL program. I am 99% sure I can get it ported into LCNC
# Panel LEDs
Time to create page: 0.066 seconds
