Reuse signal in postgui hal file
21 Oct 2023 21:44 #283461
by Guglielmi
Reuse signal in postgui hal file was created by Guglielmi
Hello,
I would like to show the spindle frequency on my HMI.
The frequency is read through modbus and it's linked already to a signal "actual_speed", I use it to perform some check in ladder..
Well, in postgui, I would like to use the same signal and link it to a HALLabel.
It's possible to reuse the signal defined in the HAL file into postgui HAL?
Should I copy it in a ladder pin?
Bye
Andrea
Bye
Andrea
- Thank you received: 5944
22 Oct 2023 00:29 #283469
Replied by tommylight on topic Reuse signal in postgui hal file
Probably yes, give it a try, LinuxCNC is pretty good at pointing out errors.It's possible to reuse the signal defined in the HAL file into postgui HAL?
22 Oct 2023 07:06 #283483
by Guglielmi
Replied by Guglielmi on topic Reuse signal in postgui hal file
Of course I tried a lot before write.. so just reusing the signal doesn't work, in postgui raises an error for signal not existing, I tried also to use a classicladder variable even it's not a nice solution without find a way.
I searched a lot in HAL documentation and on the web looking for a kind of syntax to define signal global.. nothing.
I had the idea to move all related to spindle frequency in the postgui.. maybe in this way it works but I'm also curious to know if it's possible.
So I wrote the post.
Code in the mail HAL:
Code in postgui HAL:
It doesn't work, error:
hmi_postgui.hal:31: Pin 'classicladder.0.floatin-00' was already linked to signal 'actual_speed'
but again here I'm trying to use floatin-00, I prefer to use actual_speed directly if possible.
Andrea
net speed_in conv-s32-float.0.in <= classicladder.0.s32out-03
net actual_speed conv-s32-float.0.out => spindle.0.speed-in
net actual_speed => near.0.in2 classicladder.0.floatin-00
net SpindleFreq classicladder.0.floatin-00 => AG_CncHmi.lblFreq
Andrea
22 Oct 2023 07:48 #283484
by chris@cnc
Does this work?
Replied by chris@cnc on topic Reuse signal in postgui hal file
net actual_speed => near.0.in2 classicladder.0.floatin-00 AG_CncHmi.lblFreq
22 Oct 2023 07:55 #283485
by Guglielmi
The problem is that AG_CncHmi.lblFreq is a label of my HMI so it should be handled in postgui,
this line of code is in the main HAL ...
22 Oct 2023 08:31 #283488
Alternatively, use this in your postgui
Replied by rodw on topic Reuse signal in postgui hal file
That is not a problem. Using a postgui file just changes the order of hal loading. Its still updated in real time, but the gui may not refresh immediately.The problem is that AG_CncHmi.lblFreq is a label of my HMI so it should be handled in postgui,
net actual_speed => AG_CncHmi.lblFreq
The following user(s) said Thank You: Guglielmi
22 Oct 2023 11:31 #283492
by Guglielmi
Thanks for answer.
the order of call is the correct one if I'm not wrong:
So the postgui is called after.. the order you mean the order inside the ini, right?
I tried your line of code and it works.. incredible because it was the first I try.. or most probably the mistake is
that I tried with:
maybe it is considered differenty.. I got this error:
hmi_postgui.hal:27: Pin 'actual_speed' does not exist
that confused my.. "does not exist" it's not really true. It works just removing SpindleFreq signal..
Perfect! Tanks a lot rodw!
HALFILE = cnc3040.hal
# list of halcmd commands to execute
# commands are executed in the order in which they appear
#HALCMD = save neta
# Single file that is executed after the GUI has started. Only supported by
# AXIS at this time (only AXIS creates a HAL component of its own)
POSTGUI_HALFILE = hmi_postgui.hal
that I tried with:
net SpindleFreq actual_speed => AG_CncHmi.lblFreq
