Only half of Logitech 310 buttons showing up in Hal
06 Jan 2024 23:42 - 06 Jan 2024 23:46 #290016
by Radneck
Only half of Logitech 310 buttons showing up in Hal was created by Radneck
My old Logitech 310 stopped working so I bought a used one on ebay. All the buttons and hats on the used 310 work correctly using a windows based joypad test.
less /proc/bus/input/devices shows the new F310 correctly
Everything with "input.0.abs-XXXXX" shows up in HAL and works correctly
None of the "input.0.btn-XXXX" (like input.0.btn-thumb) pins are showing up ? I trield adding the permission to the /etc/udev/rules.d folder but it made no difference
I am running linuxcnc 2.9
Any ideas ?
Any ideas ?
Last edit: 06 Jan 2024 23:46 by Radneck. Reason: cuz I felt like it
07 Jan 2024 02:17 #290027
by Radneck
Replied by Radneck on topic Only half of Logitech 310 buttons showing up in Hal
Nevermind. The problem was the "X or D" button on the back of the controller was set to X
- Thank you received: 5944
07 Jan 2024 02:23 #290028
Replied by tommylight on topic Only half of Logitech 310 buttons showing up in Hal
Thank you for reporting back.
