spindle.N.on missing from docs
24 Jan 2024 13:32 - 24 Jan 2024 13:33 #291520
by petmakris
spindle.N.on missing from docs was created by petmakris
I see that spindle.N.on is referenced in many examples on the net but also in the spindle documentation of linuxcnc:
linuxcnc.org/docs/html/examples/spindle.html
But it seems like missing from the man page. How could that be?
I have the impressions the the pins are autogenrated from the .comp file (or something similar)
linuxcnc.org/docs/html/man/man9/spindle.9.html
Last edit: 24 Jan 2024 13:33 by petmakris.
24 Jan 2024 15:25 #291526
by spumco
Replied by spumco on topic spindle.N.on missing from docs
NOTE: This component is unfortunately named and creates pins with names very much like those created by the motion component.
In nearly every case this is not the documentation page that you are looking for.
See linuxcnc.org/docs/html/man/man9/motion.9.html instead.
The pin you are referring to is in the motion component.
The following user(s) said Thank You: petmakris
Time to create page: 0.064 seconds
