Modbus-RTU control of a MOLLUM VFD
- echristley
- Thank you received: 21
31 Jan 2024 01:38 #292034
by echristley
Modbus-RTU control of a MOLLUM VFD was created by echristley
I got a
Mollum VFD
. This is one of the smallest VFDs on the market. Nice when trying to pack everything in a box. I think it is the same as the
BD600 series
that StepperOnline sells. Box is the same size, and the manuals look identical.
I'm attaching the HAL file I created to allow LinuxCNC to talk to it.
My custom_postgui.hal contains,
#set up the spindle monitor with pyvcp
loadrt scale names=scale_torque,scale_power,scale_current,scale_bus_voltage,scale_freq
addf scale_torque servo-thread
addf scale_power servo-thread
addf scale_current servo-thread
addf scale_freq servo-thread
setp scale_torque.gain .01
net torque_scale scale_torque.in mb2hal.torque.torque.float
net torque scale_torque.out => pyvcp.torque
setp scale_power.gain .1
net power_scale scale_power.in mb2hal.power.power.float
net power scale_power.out => pyvcp.motor_power
setp scale_current.gain .01
net current_scale scale_current.in mb2hal.current.current.float
net current scale_current.out => pyvcp.current
#voltage doesn't need scaling
net voltage mb2hal.voltage.voltage.float => pyvcp.voltage
setp scale_bus_voltage.gain .1
net bus_voltage_scale scale_bus_voltage.in mb2hal.bus_voltage.bus_voltage.float
#net bus_voltage scale_bus_voltage.out => pyvcp.bus_voltage
setp scale_freq.gain .1
net freq_scale scale_freq.in mb2hal.freq.freq.float
#net freq scale_freq.out => pyvcp.freq
#fault messages don't need scaling
net vfd_fault mb2hal.fault.fault.int => pyvcp.fault
The following user(s) said Thank You: andypugh, smc.collins
Time to create page: 0.082 seconds
