linking and unlinking a pin based on motion-enabled
12 Feb 2024 15:07 #293151
by linuxfan
linking and unlinking a pin based on motion-enabled was created by linuxfan
Hi all,
I have a net lines:
net ATC-pos-cmd joint.3.motor-pos-cmd => cia402.3.pos-cmd
net ATC-pos-fb joint3.motor-pos-fb <= cia402.3.pos-fb
net ATC-pos-posthome limit3.0.out => joint3.posthome-cmd
I would like limit3.0.in to be connected to ATC-pos-fb only when controller is disabled - when motion.motion-enabled pin is set to false.
When motion.motion-enabled is true, I would like to disconnect limit3.0.in from ATC-pos-fb, as once controller is enabled, I want to feed my own position into it.
Before controller is enabled and before drives are enabled, I want it to be connected to ATC-pos-fb, as I am using absolute encoders, so no homing is required. But obviously if current position read from encoder is for example 5000, and limit3.0.in is zero or some other position, motor will jump abruptly first time when machine is enabled.
So i'd like to achieve something like this:
If (motion.motion-enabled == false)then
linksp ATC-pos-fb limit3.0.in
else
unlinkp limit3.0.in
end
I have a net lines:
else
unlinkp limit3.0.in
end
12 Feb 2024 16:29 #293153
Replied by PCW on topic linking and unlinking a pin based on motion-enabled
Seems like this would be best done with a "mux2" component
12 Feb 2024 17:39 - 12 Feb 2024 17:40 #293156
by linuxfan
Replied by linuxfan on topic linking and unlinking a pin based on motion-enabled
Thanks for a quick reply. I was suspecting that mux2 would be a way to do this. However I am totally new to linuxcnc.
Would you mind sharing exact code with mux2, that would work for my case?
Last edit: 12 Feb 2024 17:40 by linuxfan.
12 Feb 2024 18:42 #293159
This is just an example that sets the limit3 source to
ATC-pos-fb when motion is not enabled and 0
when motion is enabled
loadrt mux2
addf mux2.0 servo-thread
net ATC-pos-fb mux2.in0
setp mux2.0.in1 0
net limit3source mux2.0.out limit3.0.in
net motion-enabled motion.motion-enabled mux2.0.sel
loadrt mux2
setp mux2.0.in1 0
13 Feb 2024 10:01 #293212
by linuxfan
I tried your approach, and while it works fine for connecting ATC-pos-fb to limit3.0.in, it doesn't achieve my goal regarding disconnecting pin limit3.0.in, as instead of disconnecting it, it connects it to value zero - so pin is again not available for free input value assignment.
13 Feb 2024 12:04 #293216
Replied by Aciera on topic linking and unlinking a pin based on motion-enabled
replace:
with:
setp mux2.0.in1 0
with:
net alt_input <your hal signal here> mux2.0.in1
13 Feb 2024 12:37 - 13 Feb 2024 13:05 #293217
by linuxfan
You mean like that:
net alt_input limit3.0.in mux2.0.in1 ?
This doesn't work as limit3.0.in is already connected to mux2.0.out
For what I want to accomplish, it seems that mux won't work, as switching net of signal limit3.0.in from ATC-pos-fb to something else doesn't work for me. Once it has to be connected, and once it has to be disconnected from any other signal.
To explain what I want to achieve(maybe there is some other, better way of doing it):
When controller is disabled, I want limit3.0.in to get value from ATC-pos-fb, so when controller is back to enable, servo wont jump anywhere, as current commanded position is same as current feedback position. As soon as controller is enabled, previous value has to be retained, but pin limit3.0.in now has to become disconnected from limit3.0.in, so it is available for accepting new values, that would be passed from ngc with MDI setp command.
Last edit: 13 Feb 2024 13:05 by linuxfan.
13 Feb 2024 14:55 - 13 Feb 2024 14:58 #293229
What about:
loadrt mux2
net limit3source mux2.0.out limit3.0.in mux2.0.in1
Simpler still would be a sample/hold component
There is a sample_hold component but it uses S32 rather than float.
It would not be a big deal to re-write a float version of it though.
loadrt mux2
Last edit: 13 Feb 2024 14:58 by PCW.
- Thank you received: 5934
13 Feb 2024 15:35 #293231
Replied by tommylight on topic linking and unlinking a pin based on motion-enabled
Forum member Spumco did something about S32 to Float and it worked, more here
forum.linuxcnc.org/10-advanced-configura...ndle?start=10#293042
13 Feb 2024 16:09 #293233
The mux2 example with feedback above does work
as a floating point sample/hold (just tried)
Time to create page: 0.157 seconds
