How to reset amplifier after error?
22 Feb 2024 10:56 - 22 Feb 2024 10:58 #293970
by breezer
How to reset amplifier after error? was created by breezer
Hello,
my amplifiers have an input to reset an error in the amplifier, is there a HAL pin to perform a reset?
In addition, my amplifiers have a ready signal which is set as soon as the amplifiers are in operational mode, how can I process this signal in linuxcnc, is there a motion inhibit signal or something?
Best regards
Best regards
Last edit: 22 Feb 2024 10:58 by breezer.
22 Feb 2024 11:23 #293973
by winward
Replied by winward on topic How to reset amplifier after error?
hm
22 Feb 2024 12:37 #293975
Replied by Aciera on topic How to reset amplifier after error?
Have a look at:
joint.N.amp-fault-in
joint.N.amp-enable-out
linuxcnc.org/docs/html/man/man9/motion.9.html
Note: You can use any hal signal to reset your drives (eg 'halui.machine.is-on') or to handle your amplifier fault signal.
22 Feb 2024 21:33 #294021
by Unlogic
Replied by Unlogic on topic How to reset amplifier after error?
On my machine I added a one shot logic so that a clear fault signal is sent to the drives when I reset the e-stop (using Delta drives where the logic section remains powered during e-stop).
12 Mar 2024 19:44 #295777
by bob8020
Replied by bob8020 on topic How to reset amplifier after error?
I seem to be in a similar situation... Delta AC Servo with EtherCAT. All working fine with homing via absolute encoders.
We wired E-STOP as per Delta manual, dual NC to a safety relay driving a power contactor feeding 240v to motor power on the servos. Servo control power inputs get separate 240v which stays on during E-STOP.
But (of course) we have a problem.
Say we are just powered up, LinuxCNC is enables, can jog ok.
We press E-STOP. Safety relay drops, motor power drops, but the control 240v stays up, so Delta display and buttons still working. Pressing button shows NO alarm code.
Motors freewheel as expected.
Then press Enable, the safety relay closes, 240v contactor closes, servo motor power is back.
BUT... LinuxCNC won't enable, AmpFault for all servos.
So over Ethercat the servos are telling LinuxCNC that they are faulted, but no fault code on servo front panel?
Using trial and error, the only way we seem to be able to reset things is with power cycle to the servo control power i.e. reboot the servos.
Questions:
a) Is this expected? Surprising that the servo shows no alarm but EtherCAT says ampfault.
b) Is there a way to reset after clearing E-STOP w/out a servo power cycle?
Questions:
Time to create page: 0.176 seconds
