Spindle CW and Stop Toggle Button
02 Mar 2024 19:20 - 02 Mar 2024 19:20 #294932
by N3pu
Spindle CW and Stop Toggle Button was created by N3pu
Hey
I want to add a hardware momentary pushbutton to Start the Spindle CW if it´s not turning.
If it´s turning (no matter if CW or CCW) and the Button is pushed again the Spindle should stop.
Could someone help me?
I just got the Button configured that it will run the spindle CW by pushing:
net spindle-manual-cw <= hm2_7i76e.0.7i76.0.0.input-11
But how should I handle the "if (hm2_7i76e.0.7i76.0.0.input-11 && (spindle-manual-cw OR spindle-manual-ccw)) then {spindle-manual-stop}" ?
Jannik
Jannik
Last edit: 02 Mar 2024 19:20 by N3pu.
- Thank you received: 5931
02 Mar 2024 19:24 #294934
Replied by tommylight on topic Spindle CW and Stop Toggle Button
On the phone so not much help, but search for latch or flip-flop, both are included components of LinuxCNC and both can be used for it... or toggle, aslo included.
02 Mar 2024 21:08 #294947
by spumco
Replied by spumco on topic Spindle CW and Stop Toggle Button
My spindle control uses multiclick component to turn on CW or CCW. One press CW, double-press CCW. Second button for OFF.
With one button (only) you could have double-press STOP instead of CCW. Or one press STOP, double CW, triple CCW.
Here's what I use:
Here's what I use:
signal BTN-SPIN0-ON connected to momentary pushbutton HAL-in pin.net BTN-SPIN0-ON => multiclick.s0.in
net SPIN-MAIN-FWD <= multiclick.s0.single-click-only
net SPIN-MAIN-FWD => halui.spindle.0.forward
net SPIN-MAIN-REV <= multiclick.s0.double-click-only
net SPIN-MAIN-REV => halui.spindle.0.reverse
net BTN-SPIN0-OFF => halui.spindle.0.stop
03 Mar 2024 08:10 #294988
by N3pu
Replied by N3pu on topic Spindle CW and Stop Toggle Button
Thank you.
I don´t know how to handle my "idea" with a flipflop or a toggle. I also read that some users did more or less similiar things with that kind of component, but not this exactly one. Multiclick sounds very interesting and easy, too. I didn´t knew before.
I wrote my kind of idea with an and + not component. I will give it a try today on the machine. For now it´s just written "offline":
# --- SPINDLE-MANUAL-CW AND OFF ---
#net spindle-manual-cw <= hm2_7i76e.0.7i76.0.0.input-11
#Create Spindle-Enable-NOT Signal
loadrt not count=1
addf not.0 sero-thread
net spindle-enable => not.0.in
net spindle-enable-not <= not.0.out
loadrt and2 count=2
#spindle-enable AND button_spindle THEN spindle Stop
addf and2.0 servo-thread
net spindle-enable => and2.0.in0
net button_spindle hm2_7i76e.0.7i76.0.0.input-11 => and2.0.in1
net spindle-manual-stop <= and2.0.out
#!spindle-enable AND button_spindle THEN spindle CW
addf and2.1 servo-thread
net spindle-enable-not => and2.1.in0
net button_spindle => and2.1.in1
net spindle-manual-cw <= and2.1.out
03 Mar 2024 09:40 #294997
by N3pu
This seems to work:
Thank you Guys. I begin to love this Software
loadrt and2 names=spindle_button.cw,spindle_button.stop
loadrt edge
addf edge.0 servo-thread
setp edge.0.in-edge FALSE
setp edge.0.out-width-ns 18000000
net button_spindle_full <= hm2_7i76e.0.7i76.0.0.input-11
net button_spindle_full => edge.0.in
net button_spindle <= edge.0.out
loadrt not count=1
addf not.0 servo-thread
addf spindle_button.stop servo-thread
net spindle-enable => spindle_button.stop.in0
net button_spindle => spindle_button.stop.in1
net spindle-manual-stop <= spindle_button.stop.out
addf spindle_button.cw servo-thread
net spindle-enable-not => spindle_button.cw.in0
net button_spindle => spindle_button.cw.in1
net spindle-manual-cw <= spindle_button.cw.out
03 Mar 2024 10:58 #295003
I was hooked the first time i edited a hal file, it was like entering a new universe of possibilities.
Welcome to the dark side!
03 Mar 2024 14:21 #295048
Replied by andypugh on topic Spindle CW and Stop Toggle Button
Wait until you realise just how easy it is to write your own custom HAL components.
linuxcnc.org/docs/stable/html/hal/comp.html
Time to create page: 0.283 seconds
