Two pwmgen axis and pwmgen spindle HAL file and ini for 7i95 board
03 Mar 2024 05:56 - 03 Mar 2024 05:57 #294981
by Nathan40
Please can you help setting LATHE machines with 2 axis pwmgens with encoder and 1 pwmgen for spindle with encoder for 7i95 boards:
a. HAL file
b. INI file
Regards
a. HAL file
b. INI file
Regards
Last edit: 03 Mar 2024 05:57 by Nathan40.
03 Mar 2024 14:15 #295047
Replied by andypugh on topic Two pwmgen axis and pwmgen spindle HAL file and ini for 7i95 board
Have you tried making a starting config with PnCConf? (Or possibly with MesaCT gnipsel.com/linuxcnc/mesact/index.html )
03 Mar 2024 14:36 #295050
by Nathan40
Replied by Nathan40 on topic Two pwmgen axis and pwmgen spindle HAL file and ini for 7i95 board
Tried both and ended in disaster. PncConf is not supported by 7i95. Tried created dummy profile. MesaCT threw errors.
Please help with the profiles.
03 Mar 2024 14:41 #295052
You are probably still best making a start with one of the tools, then working through the errors one by one.
03 Mar 2024 15:21 #295059
by Nathan40
Failed miserably in making profiles!
03 Mar 2024 15:37 #295060
Replied by PCW on topic Two pwmgen axis and pwmgen spindle HAL file and ini for 7i95 board
Have you tried using pncconfs discover option?
04 Mar 2024 22:37 #295167
mesact will make a working 7I95configuration for stepgens
it should not be terribly difficult to edit the main.hal file
to change the output to PWMgens instead of stepgens
Time to create page: 0.155 seconds
