no connection from parport.0.pin-10 to the halpin
- sebastian1933
27 Dec 2010 12:32 #6261
by sebastian1933
no connection from parport.0.pin-10 to the halpin was created by sebastian1933
I cann´t display a 5V signal from the parport.0.pin-10-in on the HAL-Scope in Axis.
The .hal -file contains:
net din-00 <=parport.0.pin-10-in.
On HalScope the ch.1 ist the configuret as parport.0.pin-10-in, ch.2 as din-00 and for testing HalScope I switched the ch3 to xdir.
I can see the changes from xdir on ch.3 but on ch1 and 2 I see nothing.
The pin 10 on the Parport has a LED for checking the signal after the button.
What can I check?
Please help
great Thanks Sebastian.
PS.: Antworten auch gerne auf deutsch...
What can I check?
Please help
27 Dec 2010 13:44 #6263
by BigJohnT
Replied by BigJohnT on topic Re:no connection from parport.0.pin-10 to the halpin
The easiest way to check a HAL pin is with the Show HAL Configuration from the Machine menu in Axis. Select the Watch tab and add the pins you want to monitor.
www.linuxcnc.org/docview/html/hal_basic_hal.html
If your wanting to see some real time pulse then HalScope is the one to use but a bit more difficult to understand and set up.
www.linuxcnc.org/docview/html/hal_tutori...orial%20-%20Halscope
27 Dec 2010 14:12 #6266
Replied by andypugh on topic Re:no connection from parport.0.pin-10 to the halpin
sebastian1933 wrote:
Do you have the parallel port read function attached to a running realtime thread? ie:
