How to right sequence run - pause -stop
12 Jan 2011 12:56 #6647
by aike
Replied by aike on topic Re:How to right sequence run - pause -stop
Here it is!
12 Jan 2011 14:58 #6648
by BigJohnT
Replied by BigJohnT on topic Re:How to right sequence run - pause -stop
I see the problem lol, your config is so big it won't fit on my screen... Also it is a mesa config so I can't really run it.
27 Apr 2011 11:00 - 27 Apr 2011 11:03 #9372
by piasdom
Replied by piasdom on topic Re:How to right sequence run - pause -stop
i got the below to work, but it's slow to react. i click the button and it pauses
- click again and it resumes.
i found -- if i click fast one the first click - it pauses(slow it doesn't)
click fast on second click and no reaction(slow click - resumes)
i think when clicking(first) slow it's going pause then resume in the one click
hope this helps.
net pause-btn and2.5.in0 == and2.5.in1
net pause-btn pyvcp.prog-pause == halui.program.pause
net btn-paused halui.program.resume == and2.5.out
BigJohnT - - i used your example to get this. didn't know what this was.
hm2_5i20.0.gpio.031.in_not
net program-run-btn halui.mode.auto <= hm2_5i20.0.gpio.031.in_not
net program-run-btn and2.2.in0
net program-is-auto and2.2.in1 <= halui.mode.is-auto
net remote-prg-run halui.program.run <= and2.2.out
hope this helps.
Last edit: 27 Apr 2011 11:03 by piasdom.
27 Apr 2011 11:12 #9375
by BigJohnT
piasdom wrote:
That is an input pin for a Mesa 5i20 card.
The response speed of the GUI depends on the load on the processor as far as I know...
Your code appears to be turning on both halui.program.pause and halui.program.resume at the same time.
27 Apr 2011 11:45 #9378
by piasdom
i was trying to create a button that when pressed once would
pause the program and pressed again would resume it.
27 Apr 2011 11:49 #9379
by BigJohnT
I don't think I've ever got that to work so I'll be watching to see how you do it.
27 Apr 2011 12:29 #9383
Replied by andypugh on topic Re:How to right sequence run - pause -stop
There is a component for that:
www.linuxcnc.org/docview/html/man/man9/toggle.9.html
27 Apr 2011 12:31 - 27 Apr 2011 12:32 #9384
by piasdom
it works now. i just have to first click(fast) and second click(slow)
i hold the mouse btn down longer on the second click.
not sure how to put a delay in there and don't know why it needs that.
works that way every time.
Last edit: 27 Apr 2011 12:32 by piasdom.
27 Apr 2011 12:47 #9385
by piasdom
thanks andypugh,
how do i name the variable ? i get "empty variable name"
from site
loadrt toggle [count=N|names=name1[,name2...]]
loadrt toggle [count=2|names=stop[,start]]
from site
27 Apr 2011 13:05 #9387
by piasdom
doesn't like this either
(assuming i use addf, not setp or something i never used:)
loadrt toggle count = 2
addf toggle.1 servo-thread
Time to create page: 0.397 seconds
