Tool Changer
04 Apr 2011 11:58 #8469 by andypugh
Replied by andypugh on topic Re:Tool Changer
Does "comp" work otherwise?
I have forwarded the question to the mailing list. A lot more of the developers hang out there, the forum only gets any attention from a fairly small subset of them.
04 Apr 2011 12:13 - 04 Apr 2011 12:18 #8470 by BigJohnT
Replied by BigJohnT on topic Re:Tool Changer
The command line would need a sudo to work on the installed version!
sudo comp --install toolchanger.comp
works for me.
and adding a
loadrt toolchanger
addf toolchanger servo-thread
in my hal file
it shows up in the Show Hal Configuration window.
Last edit: 04 Apr 2011 12:18 by BigJohnT.
05 Apr 2011 12:37 #8558 by andypugh
Any progress with this, I am curious to know if the code works at all (I will probably add it to the User Contributed Components part of the Wiki if it does)
06 Apr 2011 11:12 #8637 by Robin
Replied by Robin on topic Re:Tool Changer
Still no progress
the full error:
File "/usr/bin/comp", line 1297, in <module>
main()
File "/usr/bin/comp", line 1266, in main
process(f, mode, outfile)
File "/usr/bin/comp", line 1140, in process
a, b = parse(filename)
File "/usr/bin/comp", line 387, in parse
a,b = F.split("\n;;\n", 1)
valueError: need more then 1 value to unpack
don't get what i'm doing wrong :s
06 Apr 2011 12:38 #8642 by andypugh
Does
man comp
give you something which looks emc-related? I am rather wondering if that is the comp that we need...
06 Apr 2011 14:25 #8647 by BigJohnT
Are you using sudo to install the comp?
06 Apr 2011 16:19 #8649 by andypugh
Forget that, that looks like the right file. (though the reported line numbers don't actually match)
did you do the
sudo apt-get install emc2-dev
and
sudo apt-get isntall build-essential
dance?
06 Apr 2011 16:40 #8650 by BigJohnT
Would you need that on a machine with EMC installed?
06 Apr 2011 17:02 #8652 by andypugh
You need Python and gcc as a bare minimum. My impression was that comp was part of the emc2-dev package, though I might try a scratch-install to check.
06 Apr 2011 17:09 #8653 by Robin
yes tried both with and without
did you do the
and
dance?
the sudo apt-get install build-essential i didn't :s i'm no more at school atm i'll test it tomorrow.
Time to create page: 0.238 seconds
