motion.enable and motion.motion-enable - direction
01 Apr 2011 12:02 #8372
by aike
motion.enable and motion.motion-enable - direction was created by aike
Hi!
I adjust the emc now (lathe).
In HAL parameters (build in menu window in EMC) all signals are IN direction
But in documentation motion.motion-enables is OUT and motion.enable is IN.
What is right?
The HAL string
net enable <= motion.motion-enabled
is right?
What is right?
The HAL string
is right?
01 Apr 2011 14:29 #8373
by BigJohnT
Replied by BigJohnT on topic Re:motion.enable and motion.motion-enable - direction
The man page shows both as IN, are you looking at another document?
www.linuxcnc.org/docview/html/man/man9/motion.9.html
also a good read on HAL
www.linuxcnc.org/docview/html/hal_basic_hal.html
02 Apr 2011 04:17 #8381
by aike
Replied by aike on topic Re:motion.enable and motion.motion-enable - direction
BigJohnT wrote:
Please read:
www.linuxcnc.org/docs/EMC2_Integrator_Manual.pdf
the page 29. and you will see that one is in, other is out.
The string net enable <= motion.motion-enabled
has the point only in one thing - if this pin is out.
In pncconf the exampled hal file create this pin as out!
Hi!The man page shows both as IN, are you looking at another document?
Please read:
02 Apr 2011 11:33 #8392
by BigJohnT
Thanks, that is a typo in the manual.
You cannot create a pin as in or out, they are what they are. The arrow equal sign is meaningless and is only there to confuse/help humans.
Time to create page: 0.148 seconds
