Show final position via HAL
- Mike_Eitel
- Topic Author
- Thank you received: 185
02 Apr 2011 09:59 - 02 Apr 2011 10:06 #8387
by Mike_Eitel
Show final position via HAL was created by Mike_Eitel
Hi
I'm implementing a new jogwheel to my configuration.
( 4 axis, stepperconfig via parport, jogwheel via second parport , Ububtu 8.4 , EMC version 2.4.6 )
I use pyvcp to add informations to axis.
I can see prechoosen axis, jogging activity, and choosen scale factor.
As my mill is not the fastest, it's easy to jog/request a position that is farer than I want to go....
Therefore it would be nice to show the "position" that the axis will reach when "jogged" position is finaly reached. ( Sorry for my expressions, I'm not native English)
I looked around doc, also HAL Show and HAL Meter, that shows the "aimed to position" for an axis. Could not find any pin.
Could somebody give me a hint for that signal/pin
THX Mike
P.S.
pend-counts is not usable, nor "x"pos-cmd or "x"pos-fb
THX Mike
P.S.
Last edit: 02 Apr 2011 10:06 by Mike_Eitel.
02 Apr 2011 11:50 #8393
by BigJohnT
Replied by BigJohnT on topic Re:Show final position via HAL
I assume you mean you have a MPG to jog with and you are in position mode. Normally you use velocity mode so when you stop turning the dial the machine stops.
www.linuxcnc.org/docview/html/examples_mpg.html
- Mike_Eitel
- Topic Author
03 Apr 2011 09:57 #8410
by Mike_Eitel
Replied by Mike_Eitel on topic Re:Show final position via HAL
Hi John, THX
Yes you are right.
But some month ago I was not succesfull with the velocity mode, will retest it again.
Nevertheless I thonk it could be nice to show the precise position you want to reach... For a "manual" milling mode.
Friend of mine also likes the idea.....
Any hint's where I could find that "to go to" value and or a description how the jogimg functionality works .....
Mike
Yes you are right.
Mike
03 Apr 2011 17:10 #8419
by BigJohnT
You might look at the motion group and see if one of those gives you that info.
www.linuxcnc.org/docview/html/man/man9/motion.9.html
For manual milling to a specific point I would just use the MDI tab and type in G1 X1.234 Y2.3435 F12.3 and know you will cut that path. A little slip of the encoder wheel and you might not get what you desire...
- Mike_Eitel
- Topic Author
03 Apr 2011 18:54 #8420
by Mike_Eitel
THX John
I accept your argumets... For sure I use MDI mode ... but somehow hasjogging a little bit the "charm of manual milling"
And with my slow "hobyist" mill I could corect to the correct value, if I can see on the screen, before my mill reaches position.
I will look tommorow in the link you gave me, I hope I missed one of those pins.....
THX and good night
Mike
THX and good night
Mike
03 Apr 2011 20:27 #8423
by BigJohnT
Give velocity mode a whirl and see if you can get the "charm of manual milling" that way. With a slow mill even if you know the endpoint to me that would get me confused watching the cutter cut and twirling the hand wheel as I cut only to look up and see that I will go well past the point that I desire.
Another option is to write a comp perhaps. I have one that hijacks the Z for my torch height control.
Time to create page: 0.175 seconds
