Joypad problem, 'input.0.btn-trigger' does not exi
02 Apr 2011 10:56 #8391
by austin.mn
Joypad problem, 'input.0.btn-trigger' does not exi was created by austin.mn
while testing I had a wired logitech gamepad hooked up and working, but I am using it on a large plasma table, so it wasn't practical. I bought a logitech wireless controller but I can't seem to get it working. All I get is:
postgui.hal:34: Pin 'input.0.btn-trigger' does not exist
Is there something simple that I am just not doing?
02 Apr 2011 11:58 #8394
by BigJohnT
Replied by BigJohnT on topic Re:Joypad problem, 'input.0.btn-trigger' does not exi
The might have different names on the wireless controller.
What model are you using? That would be nice to have on my plasma table as well.
02 Apr 2011 18:24 #8395
by austin.mn
Replied by austin.mn on topic Re:Joypad problem, 'input.0.btn-trigger' does not exi
The name of the controllers when I go to terminal and type:
$ less /proc/bus/input/devices
is quite similar for the two controllers:
Name="Logitech Logitech Cordless RumblePad 2"
Name="Logitech Logitech RumblePad 2"
I have tried using both RumblePad and Cordless as the name after -KRAL
If I put a different controller on completely, a sidewinder joystick, it says no input device matching "RumblePad" was found.
So it is seeing the wireless controller, it is just not allowing it to work.
02 Apr 2011 22:15 #8396
by austin.mn
Ok, got it... The name of the button isn't a number. The name of the actual button it couldn't find was 'trigger' on the wireless controller the name for that button was a, and of course I had to change the other button names to b and c.
I found this out using this little tutorial:
#There are other mappings - from the terminal window, type "halrun -I" then load the
#"loadusr -W hal_input Dual" command, then use "show" to see all the inputs. To check
#the mapping, enter "loadusr halmeter -s pin input.0.btn-base" (as an example). In order
#to see what button or axes does what, you will have to waggle the joystick and write
#it down. There's no other way.
which was found on this page:
wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Usi...ntrol_Spindle_Speeds
I can't wait to move the machine around from across the shop... and now that I have gained a little more knowledge I will be that much more dangerous... I think it will be a while before I hit ninja status, but I do believe I have hit "kid with a slingshot" status.
Woo- Hoo I am going out to the shop to play.
02 Apr 2011 23:54 #8399
by BigJohnT
Actually the easiest way is to just run Axis and use the Machine/Show Hal Configuration window and put all the pins in the watch window. Then start pressing buttons and moving sticks.
Too bad they are out of stock...
03 Apr 2011 00:21 #8400
by austin.mn
can I run Axis without having EMC running. when I clicked the penguin on the desktop it wouldn't let emc boot up and All I got was the error screen that let me know I about the missing button.
03 Apr 2011 00:36 #8401
by austin.mn
I picked the controller up used on ebay for $20
I knew the wired logitech worked fine, so I wanted to make sure and get the same brand. There are plenty of other ones on there, but I am happy with the one I got. I just did a quick test in the house and I can use it from any room in the house just fine. I don't think that there will be an issue in the shop.
03 Apr 2011 00:51 #8402
by BigJohnT
austin.mn wrote:
You would have to comment out the offending code or just create a new one and add the line to load the gamepad.
03 Apr 2011 16:50 #8416
Replied by andypugh on topic Re:Joypad problem, 'input.0.btn-trigger' does not exi
I think you should be able to load a sample config (a p-port stepper one for simplicity) then load the gamepad in the "Show Hal Configuration" command entry box.
I haven't tried it though.
Time to create page: 0.473 seconds
