Modbus Examples?
20 May 2013 22:13 - 20 May 2013 22:28 #34432 by bigalex
Replied by bigalex on topic Modbus Examples?
Hi ArcEye.
The libgl1-mesa-dev was missing , I installed it and then run again ./configure --enable-run-in-place this is the result :
cnc@cnc-desktop:~/linuxcnc-dev/src$ sudo ./configure --enable-run-in-place
checking libgl1-mesa-dri workaround... required - need to preload /usr/lib/libstdc++.so.6
checking build toplevel... /home/cnc/linuxcnc-dev
checking installation prefix... run in place
checking for grep... /bin/grep
checking for egrep... /bin/egrep
checking for RT dir... Using /usr/realtime-2.6.32-122-rtai/bin/rtai-config as the RT signature
checking for location of kernel headers... using value from RTS: /usr/src/linux-headers-2.6.32-122-rtai
checking for cc version... found gcc in rtai-config
checking for gcc... gcc
checking whether the C compiler works... yes
checking for C compiler default output file name... a.out
checking for suffix of executables...
checking whether we are cross compiling... no
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking how to run the C preprocessor... gcc -E
checking for usability of rdtscll from asm/msr.h... no
checking for usability of linux/hidraw.h... yes
checking for libmodbus3... yes - version 3.0.1
checking for grep that handles long lines and -e... (cached) /bin/grep
checking for egrep... (cached) /bin/egrep
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking /usr/src/linux-headers-2.6.32-122-rtai/include/linux/version.h usability... yes
checking /usr/src/linux-headers-2.6.32-122-rtai/include/linux/version.h presence... yes
checking for /usr/src/linux-headers-2.6.32-122-rtai/include/linux/version.h... yes
checking for kernel version string... 2.6.32-122-rtai
checking for kernel module extension... .ko
checking kernel build system... kbuild
checking for module installation directory... configuring for run-in-place
/home/cnc/linuxcnc-dev/rtlib
configure: WARNING: --enable-run-in-place will be removed soon.
Configure without specifying --prefix to get a run-in-place build.
checking for glib... yes - 2.24.1
checking for GTK 2.4.0 or above... yes - 2.20.1
checking for libgnomeprintui-2.2... no -- printing from classicladder will not be possible
checking for g++... g++
checking whether we are using the GNU C++ compiler... yes
checking whether g++ accepts -g... yes
checking whether make sets $(MAKE)... yes
checking for ranlib... ranlib
checking for ar... /usr/bin/ar
checking for install... /usr/bin/install
checking for sed... /bin/sed
checking for ps... /bin/ps
checking for kill... /bin/kill
checking for whoami... /usr/bin/whoami
checking for awk... /usr/bin/awk
checking for insmod... /sbin/insmod
checking for rmmod... /sbin/rmmod
checking for lsmod... /sbin/lsmod
checking for pidof... /bin/pidof
checking for ipcs... /usr/bin/ipcs
checking for fuser... /bin/fuser
checking for mandb... /usr/bin/mandb
checking for python... /usr/bin/python
checking whether to build documentation... no
checking for kernel math support... ok, using RTAI's libm kernel module
checking for adeos... not found
checking for rtai_hal... /usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko
checking for rtai_ksched... /usr/realtime-2.6.32-122-rtai/modules/rtai_ksched.ko
checking for rtai_fifos... /usr/realtime-2.6.32-122-rtai/modules/rtai_fifos.ko
checking for rtai_shm... not found
checking for rtai_sem... /usr/realtime-2.6.32-122-rtai/modules/rtai_sem.ko
checking for rtai_math... /usr/realtime-2.6.32-122-rtai/modules/rtai_math.ko
checking for rtai... not found
checking for rt_mem_mgr... not found
checking for rtai_sched... /usr/realtime-2.6.32-122-rtai/modules/rtai_sched.ko
checking for rtai_libm... not found
checking for rtl... not found
checking for mbuff... not found
checking for rtl_time... not found
checking for rtl_sched... not found
checking for rtl_posixio... not found
checking for rtl_fifo... not found
checking for ANSI C header files... (cached) yes
checking for sys/wait.h that is POSIX.1 compatible... yes
checking for semtimedop... yes
checking for sincos function... yes
checking for __sincos... no
checking for tcl... tclConfig.sh not found, trying tcl.h and libs.
If it doesn't work try running ./configure --with-tclConfig=<path to tclConfig.sh>
checking tcl.h usability... no
checking tcl.h presence... no
checking for tcl.h... no
checking for library containing Tcl_Init... no
configure: error: tcl lib not found
Sorry ArcEye but I have really problems handling Linux and this kind of stuffs .
So do not blame me .... I need your help ....
I can see TCL library not found , but what it means .... I don't know. :blush:
bigalex :blink:
Last edit: 20 May 2013 22:28 by bigalex.
20 May 2013 22:40 - 20 May 2013 22:41 #34440 by ArcEye
Replied by ArcEye on topic Modbus Examples?
sudo apt-get install tcl8.4 tk8.4
I think it needs 8.4 rather than 8.5
( Possibly tcl8.4-dev tk8.4-dev if you still get problems - I installed it all so long ago it is hard to remember)
Last edit: 20 May 2013 22:41 by ArcEye.
20 May 2013 22:49 #34442 by bigalex
Hi.
I should have already installed the 8.4 version because when I make the command
I got the message that the tcl8.4 and tk8.4 are already the most recent version .
bigalex :blink:
20 May 2013 22:53 #34444 by ArcEye
Then try tcl8.4-dev tk8.4-dev
20 May 2013 23:02 #34446 by bigalex
Hi.
One step forward ......
I made
sudo apt-get install tcl8.4-dev tk8.4-dev
Now I have this error message
checking for tcl... /usr/lib/tcl8.4/tclConfig.sh found
checking for tk... /usr/lib/tk8.4/tkConfig.sh found
checking for BWidget using /usr/bin/tclsh8.4... found
checking for BLT using tclsh8.5... found
checking for X... libraries , headers
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking X11/extensions/Xinerama.h usability... yes
checking X11/extensions/Xinerama.h presence... yes
checking for X11/extensions/Xinerama.h... yes
checking for XineramaQueryExtension in -lXinerama... yes
checking for X11/Xaw/XawInit.h... no
checking for XawDialogGetValueString in -lXaw... no
configure: WARNING: Xaw lib missing, you won't be able to build/run xemc. try installing it with 'apt-get install libxaw7-dev'
checking readline/readline.h usability... no
checking readline/readline.h presence... no
checking for readline/readline.h... no
checking readline/history.h usability... no
checking readline/history.h presence... no
checking for readline/history.h... no
Trying readline without -ltermcap
checking for readline in -lreadline... no
Trying readline with -ltermcap
configure: error: Required library 'readline' missing.
bigalex :blink:
20 May 2013 23:11 #34447 by ArcEye
It's just telling you that you need to install libreadline
Try this and you will have everything you should need, some you already have now
sudo apt-get install cvs build-essential fakeroot debhelper libpth-dev libgtk2.0-dev kernel-wedge tcl8.4-dev tk8.4-dev bwidget python2.5-dev python-tk python-dev libglu1-mesa-dev libgtk2.0-dev libgnomeprintui2.2-dev libncurses5-dev libxaw7-dev gettext libreadline5-dev lyx texlive-extra-utils imagemagick texinfo groff qt3-dev-tools
20 May 2013 23:28 #34448 by bigalex
Hi.
I tried your advice but I get a problem with Python2.5 .
So I've installed libreadline5-dev and I've removed tcl8.4-dev tk8.4-dev because was needed tcl8.5-dev tk8.5-dev.
Now I have :
checking for Xmu headers... checking X11/Xmu/Xmu.h usability... no
checking X11/Xmu/Xmu.h presence... no
checking for X11/Xmu/Xmu.h... no
configure: error: Required Xmu header missing. Install it, or specify --disable-python to skip the parts of LinuxCNC that depend on Python
Do I have to install libxmu ?
bigalex
20 May 2013 23:45 #34450 by ArcEye
The trouble you had was that it has been deprecated, the error message tells you what to do
apt-get install python-old-doctools
21 May 2013 13:52 - 21 May 2013 13:52 #34484 by bigalex
Hi ArcEye.
I did as you mentioned:
I run again:
and I have still this :
So if it is too complicated to get it running maybe I have to stop this .
I don't want to profit by your courtesy.
One question .... I understood that mb2hal is a hal component isn't it ?
Why it is not possible install it in a simplest way ?
This question is only to understand .
I don't want to criticize anybody.
bigalex :blink:
Last edit: 21 May 2013 13:52 by bigalex.
21 May 2013 14:55 #34485 by ArcEye
The error is just telling you what is missing from your system, you just need to install it
sudo apt-get install libxmu-headers
mb2hal is a component only available in 2.6, I assume it either uses features not available in 2.5 or it is considered so experimental that it is not in a mainstream distribution.
Once you have compiled Linuxcnc you will have built mb2hal also, so keep at it
