LinuxCNC as a ModBus HMI
06 May 2017 10:28 #92739
by bymccoy
LinuxCNC as a ModBus HMI was created by bymccoy
Hi
I've been looking for a Linux based project that I can use reliably for building machine HMI, and struggling to find anything either still actively developed or that isn't a proof of concept school project.
I'm using LinuxCNC for CNC machines, so makes sense to use the same platform for "simpler" machines.
So first things first, a quick definition - by HMI, I mean just an HMI - not a PLC, but something that graphically displays a process or menus to interact with a PLC (or maybe another LinuxCNC system, but via a bus). I'm not looking for a PLC; they're plentiful, reliable and cheap these days. It's the HMI that are a struggle to find. They're normally cheap Chinese, and likely to be poorly coded, web browser based (with the client code in Java) or super expensive solutions (Siemens, Schneider, B&R) that are normally embedded Windows CE. The only place for "PLC" logic on an HMI is just to create logic for the interface and user interaction itself (i.e. enable button X in mode X, but disable buttons A, B, C etc) but that's probably better being inside the UI Python code anyway. An HMI's code should be non-essential to a machines safe running!
To clarify, with an HMI it doesn't need to be "realtime" as you'd require for controlling steppers/servos, it needs to be fast, but if you compare what's on the market, they're all low-spec embedded SOC devices or its server/client web based tech, so even a non-realtime solution would outperform this stuff. Anything that's realtime shouldn't be near an HMI - they're just to show an operator what's happening and enable them to control the machine in some way. E-stops and safety functions have to go through safety relays or safety PLCs, and never via HMI too!
So, what is the most stripped back configuration of LinuxCNC? Will it work with me removing everything excluding ClassicLadder (for Modbus and basic UI logic) and PyGTK? I'd even like to try it on small embedded touchscreens, which normally have be specs of an RPI, so the less that's loaded the better.
What's the very minimum needed in a config file to get the UI running, ClassicLadder and the ability to map pins to the UI?
Jon
Jon
09 May 2017 00:08 #92890
Replied by andypugh on topic LinuxCNC as a ModBus HMI
If you write your own UI, it could be tiny.
There is a LinuxCNC UI written for a particular 4x20 LCD display with integral buttons.
github.com/LinuxCNC/linuxcnc/blob/master...c/usr_intf/emclcd.cc
I don't know if it ever worked.
I often work with LinuxCNC with only a single component loaded.
To get an absolutely minimalist LinuxCNC.
That has nothing at all. You probably want a little more than that. Maybe a super-expensive 7408 chip?
Maybe I misunderstood the question
halrun
loadrt and2 count=4
The following user(s) said Thank You: bymccoy
09 May 2017 12:14 - 09 May 2017 12:14 #92911
by bymccoy
Replied by bymccoy on topic LinuxCNC as a ModBus HMI
Hi Andy,
No that's close...
All I need is enough to have a tiny/simple UI running and ClassicLadder with modbus.
However, reading into ClassicLadder, is it really the case that without the CL UI running, that modbus doesn't work?
J
No that's close...
J
Last edit: 09 May 2017 12:14 by bymccoy.
09 May 2017 12:17 #92912
I don't know, I have never actually used CL (or modbus, other than the hy_vfd version)
It should be a fairly easy experiment to find out.
- Thank you received: 1369
09 May 2017 13:32 - 09 May 2017 13:36 #92924
I think it might be true. I only ever experimented a little with Modbus in Classicladder. (Just enough to see it would not suit my needs.)
Perhaps using Mb2hal would be a better option for you? You might even be able to do all your logic in Hal and not use CL at all.
Replied by Todd Zuercher on topic LinuxCNC as a ModBus HMI
Hi Andy,
No that's close...
J
Last edit: 09 May 2017 13:36 by Todd Zuercher.
11 May 2017 18:24 #93037
Replied by cmorley on topic LinuxCNC as a ModBus HMI
It is possible to hide Classicladder's GUI while using modbus - there is a HAL pin to do it.
Chris M
Chris M
12 May 2017 11:23 #93068
by bymccoy
Thanks guys...
From the sounds of it, MB2HAL will be a better option, although, maybe a dumb question, but where/how can I create I/O logic (the stuff that doesn't belong in the view/UI layer) other than AND/OR etc, or do I need to build a custom HAL component for that? My reasoning behind using CL was so that I could have logic as well as the ModBus interface. However, from the sounds of it, even though I can hide the UI for CL, it's not quite an 'embedded' experience, whereas I can create an end-to-end experience using a custom GUI and MB2HAL.
I feel like I've been asking some really dumb questions about use/setup/architecture - but I've struggled to understand the architecture/config of LinuxCNC, purely as I haven't seen/found any structural flow charts (if they exist) showing how it all fits together. It's a combination of lack of time at present to experiment and maybe not finding the right style of documentation that clicks with me (I've worked on lots of very large and scary platforms and code stacks so not adverse to figuring stuff out the hard way).
From what I understand, the core of LinuxCNC is a realtime scheduler, and enables 'wiring' of virtual IO. Functionality that actually drives something is achieved through HAL components (that are also scheduled according to need), ie MESA IO, Motion Planning, ClassicLadder etc, so we can wire these physical/virtual interfaces...
12 May 2017 12:39 #93077
There are a number of hal logic components.
linuxcnc.org/docs/html/hal/components.ht...d_bitwise_components
Really, I don't think the basic concept of Hal is all that different from a ladder program.
But if programming in a ladder environment is easier for you, it is simple to use Mb2hal with Classicladder. I am doing this on a machine. I was not able to use the Modbus part of CL in my application because. the number of separate blocks of registers I needed to read or write to exceeded the limit of 16 that CL can do. (I needed 32 total, 4, for each of 8 VFDs on a gang router.)
12 May 2017 13:41 #93083
by bymccoy
Thanks Todd!
Using boht MB2HAL and CL seems a good idea - I get more I/O plus it's seamless (ie no gui or hacks to hide CL gui), but if need to program in ladder then I can...
Will have a play around with that I think then!
12 May 2017 14:15 #93088
The limit to the number of blocks of registers CL can read or write to is not the limit of the number of registers that can be read or written. Confusing? Not really, CL can read or write to a large number of contiguous registers as a single block. So reading say 50 (an arbitrary number I just chose) registers can occupy only one of CL's 16 register read/write commands, giving you 50 input points in one fell swoop. (and Mb2hal can work similarly.) I was hamstrung by the way the VFDs I was using organized their Modbus control requiring separate reads and writes of non-contiguous registers to operate.
Time to create page: 0.257 seconds
