Can a PLC run a random tool changer?
- sspeed33317
12 Feb 2019 09:29 #126255
by sspeed33317
Can a PLC run a random tool changer? was created by sspeed33317
Sorry a little off topic,
Can a PLC do all of the work of random tool changing in itself?
Example, the PLC only taking in the commanded tool wanted and then having the pocket and tool table stored
in the PLC?
So when the signal is sent to the PLC it handles all of the tool change, picking the right pocket for the tool , advancing the tool barrel , running the swing arm , unclamp and clamp the spindle and then just sends back a signal that the tool change is completed.
Thanks for any input...
in the PLC?
- Thank you received: 1370
12 Feb 2019 13:24 #126265
Replied by Todd Zuercher on topic Can a PLC run a random tool changer?
I'm sure it can be done (that is how many of the big CNC controls do it.) But Linuxcnc can do random tool changers on it's own without resorting to programming it into a PLC.
- sspeed33317
24 Feb 2019 12:59 #127051
by sspeed33317
Replied by sspeed33317 on topic Can a PLC run a random tool changer?
i dont get on here much...... I've got a old HAAS that ive had for a few years and I finally have a permanent place for it ... but was just wondering how it was done inside a PLC..
25 Feb 2019 03:08 #127081
I've never set up a tool changer. I'd start by reading the pertinent sections of the manual. Then search the forum and mailing list archives. I know I've read related threads.
25 Feb 2019 14:01 #127107
by pl7i92
Replied by pl7i92 on topic Can a PLC run a random tool changer?
ATC is more Fun to Build on the Hardware Side
then actually going to control it .
Retrofit might be different as Safty switches junp in and give you some headbang
There is always Help around here
03 Mar 2019 13:22 #127601
by BigJohnT
Replied by BigJohnT on topic Can a PLC run a random tool changer?
Here is a sim of a classicladder tool changer for a lathe.
gnipsel.com/files/linuxcnc/configs/cl-turret-sim.zip
JT
JT
Time to create page: 0.484 seconds
