Modbus more Inputs?
17 Oct 2019 06:16 #148075
Modbus more Inputs? was created by Aciera
I've got a machine panel connected via modbus to classicladder where I have used up all binary variables %B0 to %B14. Is there a way to add more variables?
17 Oct 2019 06:48 #148083
by pl7i92
Replied by pl7i92 on topic Modbus more Inputs?
this seams to be on HEX limitation
as modbus is a simple serial why dont you write a COMP for your panel that you can set all pins in HAL
or even as a PYthon file a given advance you can have as many halpins to your comp as you need
and can easy connect as a standard HAL command with IO logic
17 Oct 2019 09:17 #148099
Replied by cmorley on topic Modbus more Inputs?
linuxcnc.org/docs/2.7/html/ladder/classi...dder.html#_variables
There are actually 20 bits be default, but you can change that when you load the realtime component of classicladder.
Chris
Chris
17 Oct 2019 09:19 #148100
I'll add that unfortunately the status window only shows 15 bits even if there are more.
17 Oct 2019 11:25 #148109
Replied by Aciera on topic Modbus more Inputs?
Chris!
Thank you that solves everything!
Dave
Dave
17 Oct 2019 11:26 #148110
I'm still a beginner here. So I have no clue what a comp is...
Time to create page: 0.072 seconds
