linuxcnc classicladder ATC 12 tool
- aluplastvz
- Thank you received: 9
25 Nov 2020 21:01 #190288
by aluplastvz
linuxcnc classicladder ATC 12 tool was created by aluplastvz
I experimented a bit and succeeded
Thanks JT for the tutorial
- Online
- Thank you received: 5934
25 Nov 2020 21:06 #190290
Replied by tommylight on topic linuxcnc classicladder ATC 12 tool
Nicely done !
Svaka ti cast.
Svaka ti cast.
- aluplastvz
25 Nov 2020 21:17 #190291
by aluplastvz
Replied by aluplastvz on topic linuxcnc classicladder ATC 12 tool
Thanks, Tom
Pozdrav
Pozdrav
07 Dec 2020 19:19 #191340
by Becksvill
Replied by Becksvill on topic linuxcnc classicladder ATC 12 tool
hey do you mind sharing your config? I have a similar lathe
I could re invent the wheel but might as well check out what you did.
Andrew
Andrew
- aluplastvz
08 Dec 2020 17:45 #191435
by aluplastvz
No problem, I'm next to the machine tomorrow, so I'll post the configuration files here.
Hello
Hello
09 Dec 2020 01:33 #191454
by Becksvill
That would be awesome.
I have never used linuxcnc on a lathe before and would to see the rest of your set up to if possible. If you have time for a chat can you Email me please.
You can find my email at carbidecutters.co.nz. Regards
Andrew
Andrew
- aluplastvz
09 Dec 2020 16:54 #191504
by aluplastvz
Hello Andrew
I access my cnc lathe files they are a bit messy but they work so if you can help someone i will be glad
Greeting
Greeting
10 Dec 2020 22:02 #191611
by Becksvill
awesome
I think most of it makes sense
hey because you send me the whole config I saw all andys lathe macros.
I have not dived into glade or pyvcp much yet
if I changed all the hal connections to suit my hardware how hard do you think it would be to get the lathe conversational stuff working just on a sim? I can handle the hal connections fine I think and the ladder logic makes sense
Andrew
Andrew
- aluplastvz
11 Dec 2020 07:17 #191650
by aluplastvz
Yes it is a complete configuration so it should work if you change it.
What hardware do you use?
greeting
greeting
The following user(s) said Thank You: Becksvill
17 Dec 2020 11:12 #192239
by Becksvill
I use a mesa 6i25 and 7i77 - 7i84 combo
i am pretty confortable changing mesa pin names etc. its just the pyvcp stuff that I get stuck with.
I have three weeks off over christmas and all my servos just turned up so I will attack this then and hopefully we can all work it out.
I would like to use a stock standard linuxcnc if I can rather than pathpilot
but will just see how good axis can be with the modifications
Andrew
Andrew
