linuxcnc classicladder ATC 12 tool
19 Jun 2021 03:44 #212381
by Ingo
Replied by Ingo on topic linuxcnc classicladder ATC 12 tool
Hi Aluplastvz,
I found your ATC12 amazing, I tried to unzip and it gave a problem, could you send it again?
Thank you very much
Ingo
Thank you very much
Ingo
24 Jun 2021 17:20 #212837
by Ingo
Hello Aluplastvz, I was looking at your ATC12, I managed to unzip the file. Sorry for the questions, I'm learning about it… I'm making a machine very similar to yours, I managed to create the part of the spindle axes, the Hal and classicladder part, plus the ATC part I'm suffering a lot…, I thought about using your project I don't know if are you all right? More even if use how can I do to put your Hal inside my Hal machine? The Classicladder same thing? I also noticed that you used GUI Axes and I'm using Gmoccapy will I have problems?
Ingo
Ingo
- aluplastvz
- Thank you received: 9
26 Jul 2021 22:30 #215992
by aluplastvz
Replied by aluplastvz on topic linuxcnc classicladder ATC 12 tool
Sorry please I haven't been following the forum lately I'm sending you a file tomorrow
greeting
greeting
28 Jul 2021 02:39 #216104
by Ingo
Thank you Aluplastvz, tell me something, is your ATC12 the one that turns only one way and reverses the rotation to lock? How do you change the tool manually?
- Thank you received: 5934
28 Jul 2021 09:56 #216116
Replied by tommylight on topic linuxcnc classicladder ATC 12 tool
@Ingo,
Please refrain from reporting normal posts, report only spam or inapropriate posts.
Thank you.
Thank you.
28 Jul 2021 10:19 #216117
by Ingo
I'm sorry I don't understand, I'm just asking for help because I need it.
28 Jul 2021 22:11 #216152
OK, just do not click on "report this".
- aluplastvz
28 Jul 2021 22:27 #216155
by aluplastvz
Let my machine rotate the tools in one direction and lock it back.
And when changing tools manually in MDI you type for example M6 T1 G43 H1 provided you have filled in the tool table
greeting
greeting
02 Aug 2021 17:43 #216718
by Ingo
OK Tommy, I understand, sorry.
02 Aug 2021 17:46 #216719
by Ingo
You don't have a physical button for turning the turret, other than in MDI mode (M6 T1)?
Ingo
Ingo
