[Solved] Classic Lader doesn't run E-stop
02 Feb 2021 08:40 - 03 Feb 2021 10:16 #197390
by aleksamc
[Solved] Classic Lader doesn't run E-stop was created by aleksamc
In the postgui.hal I connected such pin:
But when out-00 is TRUE, machine is disabled.
Why I don't understand. I'm only move pin from hardware input to classiclader output.
net estop-ext classicladder.0.out-00 => iocontrol.0.emc-enable-in
Last edit: 03 Feb 2021 10:16 by aleksamc.
03 Feb 2021 08:58 #197526
by aleksamc
Replied by aleksamc on topic Classic Lader doesn't run E-stop
Nevertheless of emc-enable-in is true,
iocontrol.0.user-enable-out is FALSE.
What make iocontrol be deactivated?
03 Feb 2021 10:14 - 03 Feb 2021 10:15 #197536
by aleksamc
problem was solved. Answer is
here
Last edit: 03 Feb 2021 10:15 by aleksamc.
Time to create page: 0.107 seconds
