MODBUS TCP/IP ERRORs
26 Oct 2010 14:43 #4876
by 315john
MODBUS TCP/IP ERRORs was created by 315john
Hello
I am using EMC2 and classic ladded to talk to a GE-30 PLC over modbus TCP/IP. I can write to the registers. My problem is that i keep getting a Modbus error screen with no information from classic ladder and sometimes will loose my communication all together until i restart emc. Everything worked great talking to the modbus PLC simulator.....
Can anyone help?
Can anyone help?
26 Oct 2010 23:52 #4888
by 315john
Replied by 315john on topic Re:MODBUS TCP/IP ERRORs
I determined that the problems came from the cross over from the PLC simulator to the 90-30. I did not have the 1st modbus element loaded with the correct number
28 Oct 2010 00:58 #4918
Replied by cmorley on topic Re:MODBUS TCP/IP ERRORs
Could you describe exactly how you use TCP ?
I could never get it to work.
28 Oct 2010 12:42 #4927
by 315john
Yes i would be more than happy to help you... could you send me and example of what you are trying to connect to
29 Oct 2010 06:14 #4956
Well Classicladder actually can be set up as a slave.
But A modbus simulator would be good too.
29 Oct 2010 14:24 #4962
by 315john
I am working on putting a little doc together for you
31 Oct 2010 00:07 #4974
by 315john
Here is a PDF i put together to help you out. Let me know if you need anything else.
31 Oct 2010 00:09 #4975
by 315john
hmm didnt work. i can email it to you
31 Oct 2010 01:37 #4976
Replied by andypugh on topic Re:MODBUS TCP/IP ERRORs
Could you Wikify it? The EMC2 Wiki at wiki.linuxcnc.org/cgi-bin/emcinfo.pl is publicly editable. You just need to follow the instructions here: wiki.linuxcnc.org/cgi-bin/emcinfo.pl?BasicSteps to prove you are not a 'bot.
