NEW to CLASSIC LADDER~
01 Sep 2009 01:55 #764
by vincent
NEW to CLASSIC LADDER~ was created by vincent
hello everyone, i am new with EMC2's classicladder. i want to learn sth about it. is there any PDF available? can sb show me some useful documents?? and i wonder how to start the PLC modal?
PS: i used to handle my work with EMC2 to mill works~~but i am only familiar to EMC2's UI,(eg:AXIS,TkEMC~~) that's just what i know~~so pls help~
01 Sep 2009 05:02 #766
Replied by cmorley on topic Re:NEW to CLASSIC LADDER~
Hi
The EMC2 integrators manual has info on Classicladder:
PDF and HTML here:
www.linuxcnc.org/docs/
also the wiki:
wiki.linuxcnc.org/cgi-bin/emcinfo.pl
To start Classicladder in EMC you must add the realtime and user components. see the manual
If you use Stepconf then click the ladder button, it will add the components
If you want a standalone Classicladder open a Terminal enter 'halrun<enter>'
then enter these lines:
loadrt threads name1=med period1=100000000
loadrt classicladder_rt
addf classicladder.0.refresh med
loadusr halmeter
start
loadusr -w classicladder
This will start classicladder and a hal meter which will run until you close classicladder.
PDF and HTML here:
also the wiki:
loadusr halmeter
start
01 Sep 2009 07:08 #767
by vincent
Replied by vincent on topic Re:NEW to CLASSIC LADDER~
sounds great~!!! but still i found huge differences between EMC & EMC2, since i had read some PDF about EMC & EMC2. i got confused, what i only know now is that i am using "Ubuntu 8.04&EMC2 Live CD " version. oh, the work is so hard!! so can you tell me about EMC & EMC2??
Time to create page: 0.076 seconds
