gangtool setup / backtools
05 Oct 2012 11:29 #24974 by gmouer
Yes John, I read further on g10 coordinate system rotation and it does sound like that would work nicely for lathes with front/rear tooling. I also found that the G68/G69 is normally just a toggles the rotation on and off as needed for front/rear tools. Going to have to give this a dry run on the lathe today and see how it behaves.
05 Oct 2012 11:32 #24975 by andypugh
I would be interested to see how it goes. if it works then it is a simple G-code remap (as described in that link I posted earlier).
One good thing about G68/69 is that if you prefer not to use it, then you can use negative X diameters still.
05 Oct 2012 11:43 #24976 by gmouer
I don't think it is a g code remap situation. The G10 would be used to set the rotation (180 deg in this case), the G68/G69 would have to be setup to merely toggle that predefined rotation on and off. So, G68/69 would have to be added.
I believe that the commercial controllers for front/rear turrets have the 180 degree rotation done in a init string or similar considering the value would always be 180 degrees. No need for a operator to set this every time, he just selects front or rear tooling by putting a G68 or G69 along with his toolchange.
This is looking pretty good. After evaluation, it would be good to document it in the lathe docs.
05 Oct 2012 12:12 #24977 by andypugh
Why not remap G69 to issue G10 L2 R180 and G68 to issue G10 L2 R0?
Anyway, I am not at all sure that this is going to work. Someone with a lathe config in front of them needs to experiment before we go too far down this route.
05 Oct 2012 12:18 #24978 by BigJohnT
Same thing I just suggested on the IRC...
05 Oct 2012 12:19 #24979 by gmouer
I am going to play with this today on my machine. (gang tooled lathe) Linuxcnc is new to me and I may not be the best to evaluate this completely but I can certainly check the basic functionality out.
05 Oct 2012 12:20 #24980 by BigJohnT
The simple thing to do is to use G10 to check it out...
05 Oct 2012 12:30 - 05 Oct 2012 12:31 #24982 by gmouer
Thanks, BigJohnT
WIsh you had some of those suggestions earlier in this thread. Using axis coordinate system rotation for handling front/rear lathe tools was never suggested. Once known, using remap and the command formats are pretty obvious. I try not to ask things with obvious answers that can be found with a bit of research.
Last edit: 05 Oct 2012 12:31 by gmouer.
05 Oct 2012 12:32 #24983 by andypugh
I wish it had occurred to me.
I only ever thought of it as useful for skewed work in a mill.
05 Oct 2012 12:36 #24984 by gmouer
You have been extremely helpfull Andy. It looks like rotation was implemented mostly with milling in mind. Searching the web is where I found coordinate system rotation referenced to lathe front/rear tools. My friend told me about using G68 and G69 on several lathes he operated.
Its been a valuable learning experience. This question won't stump us next time ! LOL
I will report back later on how it works.
Moderators: piasdom
Time to create page: 0.087 seconds
