problem pitch theards lathe
26 Feb 2013 17:32 #30606
Replied by andypugh on topic problem pitch theards lathe
Another though. It might not be the spindle encoder. Are Z moves exactly correct?
26 Feb 2013 21:46 - 26 Feb 2013 21:50 #30610
by jlviloria
Replied by jlviloria on topic problem pitch theards lathe
Andy, Filipe thanks,
I have the following values:
1rev/hand
Encoder.05.counts = 4089 ---- 4095
Enconder.05.positions= 3.992188 ---- 3.998047
when I come back I mark the position:
Encoder.05.counts = -2 --- 2
Enconder.05.positions= 0.002929688 ---- 0.003048981
i have encoder: BEI AUTOMATION H25E-SS-1024-ABZC-8830-LED-SM18-S
My .INI have:
encoder scale= 1024
Z for my moves correctly, has a max error 20um
One thing I should say is that this machine has low-gear and high gear. but now only use low-gear. I have not been configured to work with me M141 And M142, in I'm still processing. not if it has something to do also.
thanks
1rev/hand
My .INI have:
encoder scale= 1024
thanks
Last edit: 26 Feb 2013 21:50 by jlviloria.
26 Feb 2013 22:02 #30612
by emcPT
Replied by emcPT on topic problem pitch theards lathe
It looks ok to me, but Andy knows a lot more. Maybe he can give his opinion.
Can you post your HAL file?
26 Feb 2013 22:31 #30615
It looks to me like the SCALE in the INI needs to be 4096
It is very common for encoders to count 4x as fast as expected as there are 4x as many quadrature transitions as there are encoder slots.
You would normally expect that the result would be 4x the expected screw pitch. I suspect that you don't see that because the Z-axis isn't fast enough, so you are seeing a random pitch.
(A simple test would be to make a new part at half the spindle speed, I think you would see twice the pitch).
1rev/hand
encoder scale= 1024
The following user(s) said Thank You: jlviloria
26 Feb 2013 22:57 #30617
by jlviloria
andy, you put 4096. and made the perfect thread.
the only thing I feel strange is that speedometer tells me a little more speed,
if I schedule indicated speed 200rpm at.speed tells me 350 rpm. but the thread does well.
speedometer is the of linuxcnc. no physical
Moderators: piasdom
Time to create page: 0.120 seconds
