Multi Start Threading?
- Zahnrad Kopf
- Thank you received: 3
08 Jun 2013 08:14 #35435
by Zahnrad Kopf
Multi Start Threading? was created by Zahnrad Kopf
Can we do multi start threading in LinuxCNC? Double lead... triple lead... quadruple lead... you get the idea.
Also, does LinuxCNC _always_ start threading from the exact same position? ( both rotationally and linearly )
- skunkworks
- Thank you received: 148
08 Jun 2013 09:57 #35439
by skunkworks
Replied by skunkworks on topic Multi Start Threading?
yes yes and yes.
the threading cycle is started when the encoder index is seen. So all you have to do is move the start point of the threading cycle to make multistart threads.
sam
sam
08 Jun 2013 10:06 #35440
Replied by PCW on topic Multi Start Threading?
here's a three lead:
The following user(s) said Thank You: Dinuka_Shehan
- Zahnrad Kopf
08 Jun 2013 10:07 #35441
by Zahnrad Kopf
Replied by Zahnrad Kopf on topic Multi Start Threading?
Thank you, Sam!
- Zahnrad Kopf
08 Jun 2013 10:14 #35442
by Zahnrad Kopf
Peter, we were posting at the same time. Thank you as well! PS - I got overloaded today and could not call to order the cards, so I'll have to wait until Monday. Thanks for all the help.
Moderators: piasdom
Time to create page: 0.257 seconds
