Stop and resume - spindle operations
14 Nov 2013 21:52 #40827
by emcPT
Stop and resume - spindle operations was created by emcPT
Hello to all,
In a lathe that is totally covered, we have a operator door from witch the operator loads the parts and can open the door for checking (measure) the part currently being done. We need to ensure the operator safety but at the same time allow flexibility on the machine operation.
What would be the best method to implement the following:
1)
When the machine is in automatic mode (running/cutting) and the operator opens the door, linuxcnc acts like feedhold (this should be easy enough) AND stops the spindle at the same time (this we do not know how to do).
2)
When the operator closes the door, the machine waits until something is pressed (resume feedhold is the best candidate) AND the spindle gains the desired (previous) velocity.
3)
When the door it open, even if the operator presses the spindle on or issues a MDI command for the spindle, the spindle will not rotate as the door is open.
Any idea? Is already something implemented? Someone is doing anything like we pretend?
By the way, for those that are following my questions, we currently have a machine working/producing parts, totally implemented with linuxcnc!
Thank you
1)
2)
3)
Thank you
15 Nov 2013 00:31 #40832
Replied by andypugh on topic Stop and resume - spindle operations
For situations like this I think that LUT5 is the right module.
You can then make a table of "if this input is like this, and this is like this, then the spindle-enable looks like this"
Feed hold is probably the pin to use for the axes, but for the spindle I think I would prefer to see the spindle drive being disabled, rather than relying on spindle-override being set to zero or similar.
In fact, it might even be best to hard-wire the spindle drive through a switch on the access door.
The following user(s) said Thank You: emcPT
16 Nov 2013 00:30 #40841
by JR1050
Replied by JR1050 on topic Stop and resume - spindle operations
I brought the topic of multiple instances of feedhold up in another thread. It seems the best way to do this is to access the mnl feedhold command directly, which as of now I have not figured out how to do. You can use the lut5 component as Andy suggested or you can write a short component using halui.feedhold and halui.resume. Each instance of feed hold would have its own in pin connected to halui.feedhold and conneceted to the condition that invokes it. Likewise you also will have just as many resume pins connected to halui.resume and connected to the condition that releases feedhold. I can give you an example if you would like. I have been thinking on this for a while.
16 Nov 2013 05:56 #40844
by emcPT
Replied by emcPT on topic Stop and resume - spindle operations
Although I did not implemented it, my colleague already did it.
I am almost sure that we only used simple hal commands and no component was needed.
We are indeed using the feedhold, spindle stop and also a hard wire to the spindle VFD for extra safety on the stop.
When the operator closes the door, program automatically restarts, what was our intention, as we normally open the door to clean the work piece.
It is, as far as I know, implemented, so if you (JR1050) want the relevant part of our hal file, just let me know, although we only use one condition for the feedhold, that is the door switch.
16 Nov 2013 07:12 #40846
by JR1050
Thanks for offering to.share, I wrote a multi input feed hold section into a component for my operator panels, as I have a feedhold button, a door switch, an orient routine, gear change and tool change that required feed hold at multiple instances along with error messages, that may or may not require feedhold or estop. I was just throwing out other possibilities!!
16 Nov 2013 08:29 - 16 Nov 2013 08:57 #40848
by DaOne
Replied by DaOne on topic Stop and resume - spindle operations
JR1050, I would love to see your example. I will be implementing this in the future on a machine. The thing that worries me is I remember reading about a bug. Basically if you stopped the spindle in CSS mode it would not restart correctly.
Found some info on the bug...
linuxcnc.org/hardy/lucid/index.php/itali...rpm-cap?limitstart=0
Last edit: 16 Nov 2013 08:57 by DaOne.
16 Nov 2013 09:45 #40849
Replied by cmorley on topic Stop and resume - spindle operations
If using linuxcnc 2.6 there are two pins:
motion.spindle-inhibit
motion.feed-inhibit
that may be helpful to you.
Chris M
motion.feed-inhibit
Chris M
16 Nov 2013 18:47 #40859
by newbynobi
Replied by newbynobi on topic Stop and resume - spindle operations
And in 2.6 it is possible to start and stop the spindle at any time, through an MDI command or just changing the hal pin state,
So you can also use and and component, spindle signal and door singnal to and and ouit to spindle...
Norbert
Norbert
Moderators: piasdom
Time to create page: 0.131 seconds
