eccentric turning
26 Nov 2018 20:46 #121398 by andypugh
Replied by andypugh on topic eccentric turning
Hi Andy, Do you have any further details on this component? I have an idea to make form relieved gear cutters and produce the backing off with this technique.
I have exactly the same idea, but have not, as yet, got round to it.
Now that the external-offsets branch has been merged it is technically much easier.
I am not sure what the ideal shape is, a sinusoid would be easiest for the machine to follow, but might not be the ideal relief shape.
26 Nov 2018 21:06 #121400 by Peter_Cassar
Replied by Peter_Cassar on topic eccentric turning
I think a sinusoid is OK. You would have pre-gashed gear blanks and the tool needs to retract while in the tooth gap. The commercial form relieving machines are sinusoidal and based off cams/eccentrics. quick retract would be ideal though so that would be an asymetric cam profile if it can be achieved.
Is there some code I can try or is it in the latest LinuxCNC build. I'm keen to give it a shot.
Peter
26 Nov 2018 21:17 #121401 by andypugh
I don't think I actually have anything to hand.
But it is pretty easy to write from scratch.
Which version of LinuxCNC are you currently on?
26 Nov 2018 21:18 #121402 by Peter_Cassar
thanks Andy, I use 2.7.3 will upgrade if needed.
26 Nov 2018 21:38 #121403 by andypugh
If you update to 2.8 then you can use:
linuxcnc.org/docs/devel/html/motion/external-offsets.html
In fact there is already a component to do what is required:
linuxcnc.org/docs/devel/html/man/man9/eoffset_per_angle.9.html
That will give a polygon with a certain number of sides. (It doesn't do the quick retract, but will at least serve as a proof of concept)
26 Nov 2018 21:40 #121404 by Peter_Cassar
Thanks again Andy, I'll investigate the links.
Peter.
26 Nov 2018 21:49 #121406 by rodw
Replied by rodw on topic eccentric turning
Also, when you get V 2.8 installed to get the external offsets, there are a number of sims using the new features you can study. The one turning a hexagon is quite cool to watch even on the screen!
26 Nov 2018 21:55 #121408 by Peter_Cassar
Where do I find the link to V2.8? I can only see 2.7.14
Peter.
26 Nov 2018 22:04 #121409 by andypugh
Normally you can get 2,8 (which is the unstable development version) from buildbot.linuxcnc.org, but that appears to be down at the moment.
26 Nov 2018 22:14 #121411 by Peter_Cassar
Ok then I'll keep checking when it comes back online.
Moderators: piasdom
Time to create page: 0.207 seconds
