g76 canned threading using NGCGUI sub routine
30 Dec 2013 02:39 #42172
by Davenc
Replied by Davenc on topic g76 canned threading using NGCGUI sub routine
Ok now that is working the way it's supposed to. I can set it to true and when I rotate the spindle manually it changes to false as soon as the slot in the index wheel passes through the opto coupler. Probably need to update the information in the link. Also the unlink command in the procedure needs to be corrected to unlinkp.
The G76 canned ngcgui routine runs fine as long as I have either phase A or phase B inverted.
30 Dec 2013 04:20 #42177
by BigJohnT
Replied by BigJohnT on topic g76 canned threading using NGCGUI sub routine
Thanks for the info on the typo.
JT
JT
Moderators: piasdom
Time to create page: 0.127 seconds
