Mazak Dinosaur Progress & Questions
- Zahnrad Kopf
- Thank you received: 3
07 Aug 2014 07:38 #49569
by Zahnrad Kopf
Replied by Zahnrad Kopf on topic Mazak Dinosaur Progress & Questions
Wow. Wonderful stuff! Congratulations. More videos!
07 Aug 2014 17:42 #49574
by BigJohnT
Axis is a keyboard and mouse GUI, Touchy and Gomcopy (however is it spelled) are touch screen GUI's.
JT
Replied by BigJohnT on topic Mazak Dinosaur Progress & Questions
Next questions:
- Is there a way to make the Tool icons bigger in Axis (so my touchscreen is easier to use
JT
07 Aug 2014 21:36 #49579
by Poma
It just looked so silly to have Touchy running on a 15-inch screen with 1024 resolution. Heck, each button was 3" across! My fingers are fat, but not that fat. Maybe on a 6" touchscreen. I did bump the resolution down a bit to make the Axis buttons appear bigger.
I don't recall seeing Gomcopy, though. I'll keep it in mind. Thanks!
Replied by Poma on topic Mazak Dinosaur Progress & Questions
JT
07 Aug 2014 23:04 #49581
by Poma
Here's a shot of what's going on with the spindle:
vid.me/BJK
And a picture of the re-purposed cabinet. I reused the air-air heat exchanger from the Mazak. The buttons are: Control power, E-Stop indicator, E-stop button (1 of 4 placed around the machine), and E-stop reset. The e-stop chain is a dual-channel category-0 system. So the main contactors are all opened, the drives are all given a seperate emergency stop signal (Safe-Torque Off), and EMC is also given the e-stop command.
The spindle motor is the very same 15HP, 4000 rpm Mitsubishi from the original mazak.
It takes 45 minutes to make a single pass, usually 3 passes per side (top and bottom) at 0.040" each pass.
vid.me/BJK
- johns00056
08 Aug 2014 08:31 #49591
by johns00056
Replied by johns00056 on topic Mazak Dinosaur Progress & Questions
That is quite an unusual machine. Did it start out as a milling machine?
08 Aug 2014 22:42 #49603
by Poma
Yes, I think it was a bridge mill back in the 80's.
10 Aug 2014 19:10 #49654
Replied by andypugh on topic Mazak Dinosaur Progress & Questions
I only just put together "Poma" and "Aerial ropeways"
I suspect I have had many opportunities to rely on your work.
Moderators: piasdom
Time to create page: 0.190 seconds
