How do i select motor power for my machine?
24 Jul 2014 09:15 - 24 Jul 2014 09:16 #49070
by skvallab
How do i select motor power for my machine? was created by skvallab
I use a center lathe.
for doing turning and facing operation on forged rings .
how do i select the required power rating of the motors to couple to X and Z axis?
and how to cross verify the calculation with digital instruments. like using a load cell and finding the force .
thanks in advance
vallab
thanks in advance
vallab
Last edit: 24 Jul 2014 09:16 by skvallab.
24 Jul 2014 18:10 - 24 Jul 2014 18:11 #49084
by BigJohnT
Replied by BigJohnT on topic How do i select motor power for my machine?
Your tool supplier should be able to supply cutting force and HP (Horse Power) needed for any operation.
Also on the web are hundreds of speed/feed calculators that can supply HP needed to turn a material.
JT
JT
Last edit: 24 Jul 2014 18:11 by BigJohnT.
The following user(s) said Thank You: skvallab
16 Aug 2014 15:54 - 16 Aug 2014 16:00 #49920
by vre
Replied by vre on topic How do i select motor power for my machine?
For a convetional manual lathe 1.5m between centers with prismatic Z ways and dovetail X ways 1500kg will be enough 1.8kw ac servo for Z axis and 600w for X axis both 3000rpm reduction 2:1 / 10mm pitch ballscrews (diammeter 32mm for Z / 16mm for X) ?
Or bigger servos needed?
Last edit: 16 Aug 2014 16:00 by vre.
Moderators: piasdom
Time to create page: 0.247 seconds
