Coordinate rotate about Y for taper comp?
30 Dec 2014 10:13 #54398
by clkeck1
Coordinate rotate about Y for taper comp? was created by clkeck1
Is there a way to rotate the coordinate about y to comp for tailstock taper?
30 Dec 2014 22:00 #54416
by BigJohnT
Replied by BigJohnT on topic Coordinate rotate about Y for taper comp?
The only axis you can rotate about is Z, having said that I don't see why a comp file would not work to straighten out your lathe.
linuxcnc.org/docs/html/config/ini_config.html#sub:AXIS-section
JT
JT
30 Dec 2014 22:09 #54417
by clkeck1
Replied by clkeck1 on topic Coordinate rotate about Y for taper comp?
I went ahead and fixed it the right way and realigned the tailstock.
It would be nice to be able to tweak out some taper in a part with a taper comp of some kind instead of having to edit the program of a multi dia part.
30 Dec 2014 22:25 #54418
by BigJohnT
On my Harding CHNC lathe I do 95% of the ops using ngcgui. Have you seen that?
linuxcnc.org/docs/html/gui/ngcgui.html
gnipsel.com/shop/hardinge/hardinge.xhtml
JT
JT
Moderators: piasdom
Time to create page: 0.243 seconds
