Lathe + servo spindle + emc 2.6
21 Mar 2015 08:06 #57052
by Krakus
Lathe + servo spindle + emc 2.6 was created by Krakus
Hello guys!
In our small company we have small cnc lathe.
Simple constructions made with aluminium sheets and profiles.
3nm steppers, 16x5 ball screws, 20mm square linear rails.
Not big deal but very good machine to do small things, like a nozzle for 3d printer.
How ever, our problem with machine is spindle with servo motor.
Servo is 400w estun + estun pronet-e servo driver.
We connect this servo to LPT mother card.
Step/dir connects working not bad, but we can't set up this servo.
configs
1. servo is third axis
2. servo is only spindle motor
can you help us? Any materials how start?
Best Wishes Kamil vel Krakus
configs
- andreadm0104
04 Dec 2015 08:40 #66359
by andreadm0104
Replied by andreadm0104 on topic Lathe + servo spindle + emc 2.6
Hi everybody,
I've the same situation with my lathe.
I need to use a servo motor as:
- motor for the spindle, in turning, at for example 1000RPM or more
- as third axis, for example to rotate the spindle only 45 degrees
So Krakus, I see nobody still helped you...
but have you however find some materials how start?
Thanks!
Andrea
Thanks!
Andrea
- andreadm0104
04 Dec 2015 09:16 #66361
by andreadm0104
this is an example of what I would do:
at 0:40 the machine is turning at high RPM
a 1:52 the machine is used as a divider to drill some holes
Thanks!
Thanks!
04 Dec 2015 10:52 #66366
by cncbasher
Replied by cncbasher on topic Lathe + servo spindle + emc 2.6
set up a second ini file with the servo set up as a axis
wiki.linuxcnc.org/cgi-bin/wiki.pl?Rot4thaxiskins
The following user(s) said Thank You: andreadm0104
- andreadm0104
04 Dec 2015 13:10 #66377
by andreadm0104
Are you sure this is the right way?
If I use two different ini file my workflow would be:
- start LinuxCNC with first setup
- turning
- stop LinuxCNC
- restart LinuxCNC with second setup
- drill the holes
- stop LinuxCNC
and this is exactly what now I do.
but now I need to everything in a unique session, with this workflow
- start LinuxCNC
- turning
- drill the holes
- stop LinuxCNC
because I have a production of many pieces
Or I did not understand your advice?
- turning
- stop LinuxCNC
- drill the holes
- stop LinuxCNC
- start LinuxCNC
- turning
- drill the holes
- stop LinuxCNC
04 Dec 2015 15:14 #66387
Replied by andypugh on topic Lathe + servo spindle + emc 2.6
See this diagram:
wiki.linuxcnc.org/uploads/orient.svg
(Ctrl+ will zoom in most browsers)
and this sample HAL file:
github.com/jepler/linuxcnc-mirror/blob/m...olchange/spindle.hal
This is exactly the same problem as spindle-orient on a milling machine.
- andreadm0104
04 Dec 2015 16:43 #66396
by andreadm0104
yes!
I think this is the right approach to the problem!
I now have in front of a lot of hours of study (it's really complex for me...) but at least now I know a little better where to start!
Many thanks!
Andrea
Many thanks!
Andrea
Moderators: piasdom
