Ditching Mach 3/4 LinuxCNC is The Plan!
- Contract_Pilot
- Topic Author
- Thank you received: 11
11 Sep 2015 03:31 - 11 Sep 2015 03:32 #62419
by Contract_Pilot
Replied by Contract_Pilot on topic Ditching Mach 3/4 LinuxCNC is The Plan!
Latency Test after a 1/2 hour of my son playing hard max jitter was 159,657ns so maybe not good enough for using the LPT port?
"If the numbers are 100 us or more (100,000 nanoseconds), then the PC is not a good candidate for software stepping."
Last edit: 11 Sep 2015 03:32 by Contract_Pilot.
- LearningLinuxCNC
- Thank you received: 61
11 Sep 2015 04:03 #62420
by LearningLinuxCNC
Did you make sure to disable all power saving features in BIOS?
Replied by LearningLinuxCNC on topic Ditching Mach 3/4 LinuxCNC is The Plan!
- Thank you received: 1370
11 Sep 2015 04:04 #62421
Replied by Todd Zuercher on topic Ditching Mach 3/4 LinuxCNC is The Plan!
If those are the numbers it probably isn't a good candidate for Linuxcnc at all. But have you properly configured it?
You need to be sure to turn off most if not all power saving features in the bios, as well as disabling any hyper-threading. If it is a multi core cpu, (most are anymore) it often will benefit from setting up isolcpus.
There are some tricks here
wiki.linuxcnc.org/cgi-bin/wiki.pl?The_Is..._Parameter_And_GRUB2
- Contract_Pilot
- Topic Author
11 Sep 2015 05:06 - 11 Sep 2015 05:19 #62425
by Contract_Pilot
Last edit: 11 Sep 2015 05:19 by Contract_Pilot.
- Contract_Pilot
- Topic Author
11 Sep 2015 14:34 - 11 Sep 2015 14:39 #62434
by Contract_Pilot
Well was running for hours both numbers is 125000ish had YouTube on a playlist + other items running to where it was getting bogged down! I know my laptop could not handle that the load on it it said to abuse it! 15Min of average use not hammering on it stayed 60000's
CPU Pentium 4 @ 3ghz W/2GB Ram
I Turned every power item I could find off in the bios.
Hyper-threading Disabled
On Board Audio Off
Fan On
Wake on Anything Disabled or to Stay On
Floppy Disabled
ACPI Suspend State S1 "S1 is the safest mode but consumes more power. S3 consumes less power, but some drivers may not support this state."
Gateway Midway 4000887 Board Info.
Closest MB Manual since it is a gateway dont have all the options. Even updated it to the latest Bios I could find.
So should I pitch this box and look for another with better latency or do you think it would work with a mesa card?
On Board Audio Off
Fan On
Floppy Disabled
Last edit: 11 Sep 2015 14:39 by Contract_Pilot.
11 Sep 2015 19:38 #62451
You could try using it anyway. Get started on the fun parts of the project.
Replied by andypugh on topic Ditching Mach 3/4 LinuxCNC is The Plan!
11 Sep 2015 21:08 #62466
Since I think that is a single core cpu you could try the old 8.04 based install. It usually worked much better on older single core systems.
The only problem is it would limit you to older releases of linuxcnc (I think 2.5 was the last version to support it)
- Contract_Pilot
- Topic Author
15 Sep 2015 03:55 - 15 Sep 2015 04:05 #62586
by Contract_Pilot
Last edit: 15 Sep 2015 04:05 by Contract_Pilot.
- Contract_Pilot
- Topic Author
17 Sep 2015 06:41 - 17 Sep 2015 06:49 #62667
by Contract_Pilot
Paid Tormach Their $30.00 + $7.65 Shipping! Maybe next week Mesa Combo!
Business Name:
Tormach, Inc. (The recipient of this payment is Verified)
Email:
This email address is being protected from spambots. You need JavaScript enabled to view it.
Total amount:
-$37.65 USD
Fee amount:
$0.00 USD
Net amount:
-$37.65 USD
Item amount:
$37.65 USD
Quantity:
1
Item Title:
Online Order
Item Number:
ORD20150916XX
Date:
Sep 16, 2015
Time:
16:34:17 PDT
Status:
Completed
I should have never went mach!!! LCNC way simpler just from playing around! To bad Tormach does not offer pay and download foring to be an interesting 2-3 week wait for the disk!
Was able to get every thing but the steppers to move on the new additions.
Business Name:
Email:
Total amount:
-$37.65 USD
Fee amount:
$0.00 USD
Net amount:
-$37.65 USD
Item amount:
$37.65 USD
Quantity:
1
Item Title:
Online Order
Item Number:
ORD20150916XX
Date:
Sep 16, 2015
Time:
16:34:17 PDT
Status:
Completed
Last edit: 17 Sep 2015 06:49 by Contract_Pilot.
- racedirector
- Thank you received: 41
17 Sep 2015 13:21 - 17 Sep 2015 13:22 #62672
by racedirector
Replied by racedirector on topic Ditching Mach 3/4 LinuxCNC is The Plan!
Hear, hear, I agree 100%. Was never able to get my machine to do what I wanted it to under Mach3. Under LCNC, after figuring out a few bugs, I just ran a test part with 3 different tool changes and some 3D thrown in for good measure and the machine performed flawlessly. Only touched off once manually at the beginning of the job to set Z zero, everything else was automated aside from physically changing the cuttersI should have never went mach!!! LCNC way simpler just from playing around!
Last edit: 17 Sep 2015 13:22 by racedirector.
Moderators: piasdom
Time to create page: 0.925 seconds
