Demystifying Spindle Sensors
- Trispectiv
11 Mar 2016 15:47 #71416
by Trispectiv
Replied by Trispectiv on topic Demystifying Spindle Sensors
After I converted the Orac and I was trying to use it with Mach3, I was checking the inverter frequency against the spindle RPM with a tachometer (a piece of reflective was already on the backplate when I got the lathe). Now with LinuxCNC I was just checking against the know VFD frequency and expecting the known RPM. For instance, I only get up to around 1500 RPM hen I max the VFD frequency, which should mean 2000 RPM.
11 Mar 2016 16:17 #71419
Replied by andypugh on topic Demystifying Spindle Sensors
I assume you have set the encoder scaling correctly, and have enabled counter-mode?
The encoder velocity output is in revs per second, with a factor of 60 there and a factor of 4 for quadrature you get an overall factor of 133.333. Is that what you are seeing?
- Trispectiv
11 Mar 2016 16:30 #71422
by Trispectiv
Well, for someone coming from Mach3 your post is.. complex
All I did is follow the example here:
linuxcnc.org/docs/2.4/html/examples_spindle.html
for setting my VFD PWM 0-10V signal and the encoder at the back of the spindle.
I see no counter-mode related settings in that tutorial, so I definitely did not add such a thing. I will look into that.
Same for scaling, I don't even know what that is about at this moment.
One other thing, that panel displays random erroneous RPM even when idle. Like 0-500 random numbers, even if the spindle is still.
Should I take it the software thinks I am doing quadrature while the machine is A Z only?
11 Mar 2016 16:33 - 11 Mar 2016 16:49 #71424
by cncbasher
Replied by cncbasher on topic Demystifying Spindle Sensors
i'd recon . this is mostly because of not selecting counter mode , so give it a go . and report back
see if you have this for counter-mode
setp encoder.0.counter-mode 1
( or in other words set encoder 0 counter-mode true)
i found setting the true spindle rpm equaling the shown spindle speed , and disregarding what the vfd was telling me , gave better results . and testing this at different speeds across the range .
so i.e s500 did give me 500 rpm both on my tacho and the shown spindle rpm
Last edit: 11 Mar 2016 16:49 by cncbasher.
11 Mar 2016 16:39 #71428
Section 2.1 contains
setp encoder.0.position-scale 100
You need that to be 50, and then add
But be aware that the output is in revs-per-second.
- Trispectiv
11 Mar 2016 16:50 #71431
by Trispectiv
Tough one, I checked the HAL file and I have both settings there.
50.0000 for encoder scale and mode 1
They were set by the wizard, I remember looking at the file after that and seeing that very floating 50.00000.
I guess it is one of those points were I have to attach my HAL file, huh?
(that particular box is not networked yet)
11 Mar 2016 17:03 #71434
One other way to measure spindle speed.
Put a long length of threaded rod in the spindle with a nut on it.
Using a stopwatch time how long it takes the nut to travel a set distance when you hold it and stop it turning.
That gives you an rpm measurement based on fundamental physical quantities (time and length)
Moderators: piasdom
Time to create page: 0.096 seconds
