Spindle indexing disc with opto switches
15 Apr 2016 13:55 #73347
by midyo
Spindle indexing disc with opto switches was created by midyo
I'm about to make an "encoder" from a disc and 2 of these opto switches RS 306-061. uk.rs-online.com/web/p/slotted-optical-s...rigin=PSF_438299|alt
I'm not too concerned with the single pulse index as already have this up and running and can be left as is I think?
Is the best number holes/slots 100? Comments on the choice of sensor most welcome as don't want to waste precious time!
15 Apr 2016 16:10 - 15 Apr 2016 16:11 #73349
by cncbasher
Replied by cncbasher on topic Spindle indexing disc with opto switches
they are fine , for me i'd go with a disk of 120 slots ,
however , any number of slots from say 60 will do
i have used disks with 100 , without problem
( i say 120 for the reason that it's equally divisable into 360 degrees )
all depends on how much space you have available for the diameter of the disk
Last edit: 15 Apr 2016 16:11 by cncbasher.
15 Apr 2016 16:35 #73350
by midyo
Replied by midyo on topic Spindle indexing disc with opto switches
120 it is then - makes total sense. Aslong as I can get them in, obviously I could make the disc bigger if space allows?? Is there an ideal gap size between holes/slots, or maybe a minimum gap?
cheers
cheers
17 Apr 2016 14:25 #73477
Yes, but it depends on the sensor more than anything else.
Some sensors have two detectors and can do full quadrature. I would be tempted to use one of those even if you don't wire the B-channel at the moment.
Replied by andypugh on topic Spindle indexing disc with opto switches
Moderators: piasdom
Time to create page: 0.524 seconds
