lathe tool turret EMCO codes
13 Mar 2017 10:03 #89507 by pierre
lathe tool turret EMCO codes was created by pierre
Hello everyone, I installed linuxcnc on a CNC lathe EMCO 50Turn PC, everything works except the tool changer.
I understand that Ineed to write a "small" piece of code to make it work ... I'm not stuck in this area at all.
For information, on the parallel port of the machine, regarding the tool changer, I have two pins plugged in, one is the tool index No. 1 and the other is the feedback info of change Tools ... there are 6 positions on the tool turret.
Could you guide me in the manipes to perform?
  • andypugh
  • andypugh's Avatar
  • Moderator
  • Moderator
14 Mar 2017 16:34 #89599 by andypugh
Replied by andypugh on topic lathe tool turret EMCO codes
Maybe one of these two components can help?
wiki.linuxcnc.org/cgi-bin/wiki.pl?Contri...oolchanger_component
02 Apr 2017 00:06 #90743 by turbo
Replied by turbo on topic lathe tool turret EMCO codes
This thread may help if your tool changer is close enough to the pc turn 55 forum.linuxcnc.org/30-cnc-machines/27319...55-upgrade?start=110.
Moderators: piasdom
Time to create page: 0.119 seconds
